Huge Air Compressors - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Jan 2005
    Houston
    6,350
    854
    3177
    "That motor was still spinning" because it was probably a synchronous motor, with a PF correction of 1.0, look at the nameplate, others are .80.
    The run them to fix the Power factor"
    It's true that some synch motors run at a leading PF (like .8 leading) to help power factor. Most run at 1.0PF which helps PF but to a lesser degree. But in any case, anyone running a synch motor to correct PF each night is making a costly mistake when it's still connected to a compressor. That's because the wear and tear on the compressor is significant and will outweigh the PF savings. I'm basing that on a piston type compressor specifically but it would still be the case with a centrifugal. If your power co is hitting you that hard on a demand charge....you need to find a new power co.
  2. #22
    Mar 2009
    Eureka, CA
    4,043
    872
    1502
    The power company powering the pump in the OP is a company owned setup..isn't it? No peak demand charges there.
    Stuart
  3. #23
    Dec 2004
    uk
    14,053
    4552
    6713
    Quote Originally Posted by GregSY View Post
    Nope not really, centrifugal s you can just spin em with the inputs closed, once the airs out they are just a spinning mass, most float on hydrodynamic bearings, so there really is no wear and tear in idleing. Power draws can be a hell of a lot smaller under no load than you would expect too.
  4. Likes tdmidget liked this post
  5. #24
    Nov 2011
    Central VA, USA
    426
    14
    51
    Thinking on that....
    If bearings are hydrodynamic type, seems like the start up phase might put more wear on them than just letting them idle.
    Running cold, dry and direct metal on metal until they spin up.
  6. #25
    Dec 2004
    uk
    14,053
    4552
    6713
    Quote Originally Posted by mpmar_bt View Post
    No, most larger machinery running that kinda bearing would have its own small motor and lube oil pump, often with a cooler too. Pretty std on all sorts of power generation turbines too.
  7. Likes tdmidget liked this post
  8. #26
    Jun 2009
    Michigan, USA
    2,367
    3325
    1812
    Quote Originally Posted by SIP6A View Post
    Did you work at Willow Run?
    No. I worked at one of the Grand Rapids plants. The only one that's still open.
  9. #27
    Jun 2009
    Michigan, USA
    2,367
    3325
    1812
    The run them to fix the Power factor.
    Even on weekends with all machinery shut down it took a lot of air. With all the air leaks in a plant that size it would probably take a 100 hp compressor just to maintain proper pressure on the weekends with everything shut down. They occasionally would have a pipefitter come in on a Sunday when the plant was mostly idle and listen for leaks and tag them for repairs. It was way too noisy to hear leaks when everything was running during the week.
  10. #28
    Feb 2008
    Lomita, CA
    101
    18
    The plant I work at originally had 4 4600 (12 KV feed) hp Clark compressors. They were flat 6 cylinder double acting machines with 39" bore low pressure and 19.5" bore high pressure cylinders. They were bought used in the early '60s from natural gas pipeline compression service in Canada. Extensive modification had to be performed to convert them to air service, as the liberal oil injection used in gas compression would have been an explosion risk (dieseling) in air, as well as requiring extensive post compression oil separation. At maximum operating conditions we could get 3000 pounds/minute flow at 300 psi. We have air dryers to reduce the compressed air dewpoint to below -40º F, and natural gas fired heaters that can raise the temperature to 1000+ ºF. All of this is to simulate high stage bleed air from jet engines to test the aircraft environmental control systems we design and build. Only one of the 4 recips remains in operation, the rest having been replaced by smaller IR Centac centrifugals, which are more cost effective to run at variable flow requirements (and new parts are still available, unlike the Clarks.) We also added 6 38000 gallon receivers to help with peak demand flows.
  11. #29
    Jan 2005
    Houston
    6,350
    854
    3177
    Oh, you can still get all the Clark parts you want....they're now owned by (gulp) Siemens.
  12. Likes 4GSR liked this post
  13. #30
    Sep 2010
    Oklahoma City, OK
    5,046
    907
    2117
    Quote Originally Posted by adama View Post
    Yes sir, pre-lube.
  14. #31
    Jan 2005
    Houston
    6,350
    854
    3177
    Pre lube, yes....but most slow speed recip compressors just use a self-lubed bearing with an oil ring. Bearing wear? It's not uncommon to run a motor 40 years and find the bearing still 'not worth changing'.
  15. #32
    Jul 2008
    Asheville, NC
    2,483
    1278
    1207
  16. #33
    Mar 2005
    Kansas
    7,968
    491
    3801
    Quote Originally Posted by FredC View Post
    I helped pull a cold tower up the hill in front of our place. The destination was somewhere out in west Texas. I understand a huge air compressor would have been paired with this tower to separate gases form the air.
    Would have been interesting to see the final installation.
    The tower by it self weighed 291,000 LBS. Did not see the compressor go by but a companion cold tower went by later, it was a little lighter and did not need assistance.
    Attachment 256792
    Let me know when you want to get rid of that 6030.
  17. #34
    Oct 2010
    Dewees Texas
    2,664
    29
    787
    Quote Originally Posted by gbent View Post
    Just spent $12,000 to replace a blown engine and new tires. Wish I had bought the 4640 at my6030.com instead.
    Just tried to send you a PM but my mailbox is full.
  18. #35
    Oct 2011
    West-Central Illinois, USA
    1,298
    2084
    599
    The largest I can remember were the compressors Illinois Power used to pump natural gas down in porous rock formations. Most were Clarks, don't remember the HP but they were 7200 volts with the switchgear separated from the pumps by a fair distance.
    If you were within 50 yards of one when it started you felt it through your feet. Kinda creepy...
    Matt
  19. #36
    Apr 2010
    Justin, Texas
    357
    103
    Here is the one we put in our research lab. Kinda puny at 3000 PSIG and 2000 SCFM.
    Equipment
  20. #37
    Apr 2004
    Modesto, CA USA
    7,587
    1341
    I could not find a good picture but the North Star mine(California) power house had a large compressor powered by a water wheel. Interesting thing wa sthat for a storage tank they blasted a good sized room in solid granite and closed off the entrace with a steel wall with some pipe fitting to let the air in and out.
    Bill D.
  21. Likes dalmatiangirl61 liked this post
