So I picked up an air over hydraulic tire machine that was working relatively ok and I tinkered with it and made it not working
It has two low pressure/slow hydraulic arms to break the bead on a tire.
Fluid was low and probably original so I decided to drain it and refill with fresh. Filled to spec, 10oz, up to the sight glass in the reservoir. I manually extended the cylinder arms to fill with fluid and get the air out by cracking the lines at the cylinders.
Problem now is that neither cylinder extends at all when the air is hooked up and button is pressed. There are micro air lines running to each cylinder that keep them compressed. Remove the air line and the cylinder extends out to full.
The pump was working fine, still is working fine by switch actuation. I just don't know where there could be air or how to get it out or what I might be missing.
I think the issue is somewhere near the pump/oil reservoir since neither cylinder extends at all with the pump running and everything was working correctly before I started draining fluid out.
Thoughts?
Thoughts?
