Hunter Tire Machine - Air Over Hydraulic issues - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21
    Oct 2005
    14,561
    Quote Originally Posted by dkmc View Post
    Great snappy comeback. Except you're about 6 days late and your cornflakes are all soggy now.
    Now go play in traffic junior.
    ...and a total of qty (50) posts too.....whoopee !
  2. #22
    Oct 2005
    14,561
    Quote Originally Posted by john.k View Post
    Ive always found the air /hydraulic pumps to be troublesome.....first there is an air system with generally plastic valves,then the hyd pump has little ball valves to stick .......even when its pumping OK,there isnt enough volume to flush air from the system back into the tank.............simple cure.....fit a small gear pump driven by a 2hp elekky motor..........IMHO,the attraction of air pumps to manufacturers,is you dont have lekky codes to comply with,and its also near impossible to overpressure them,as the air cylinder stalls .
    And.....automotive repair shops have lots of air available.
    There is the fact that an electric drive would need to be made EE rated for all the flammable stuff floating around in a normal garage (and sometimes spilled on the floor nearby)
  3. Likes dkmc liked this post
