Hydra-Vise??
Likes Likes:  0
Results 1 to 8 of 8
Thread: Hydra-Vise??
    May 2005
    Milwaukee, WI
    791
    16
    61
    Default Hydra-Vise??
    Ran across an older 4ton version of one of these.
    http://www.dapra.com/workholding/arn...lassic-mh.html
    How does the hydraulic clamping work? What are the up and downsides compared to a Kurt style for a manual milling machine?
    Nov 2002
    St.Louis, Missouri, USA
    2,084
    123
    467
    As far as I understand it they're great as long as in good working order. They develop problems over time like pressure bleed down and then they need parts replacement. I personally wouldn't want to be using one and find out it lost pressure the hard way?
    Dan
    Jun 2012
    Michigan
    4,736
    4345
    2878
    Hail hydra!
    Aug 2015
    Illinois
    1,423
    1015
    619
    Several years ago I worked for a company that had two hydra vises. The hydraulic spindles did not work properly. We had them rebuilt by Dapra. The hydraulics failed within weeks. I have no use for the damned things. I have a Dapra vise with a defunct air/oil spindle I would be delighted to sell to the first $100.00. It includes one set of new jaw plates and one set of re-ground plates. I was planning to make a new spindle, purely mechanical, but decided against it. Btw a new mechanical spindle from Dapra is about $1500. End of rant.
    May 2002
    South Central PA
    13,611
    2273
    3528
    plus - When they work they really squeeze the workpiece, and they open up really long for their width. Negative - They don't have the hold down feature of a Kurt, so the movable jaw can lift by the amount of wear in the guideplates.
    Nov 2019
    New Jersey
    Default will give you $100 depending on shipping cost
    Quote Originally Posted by Illinoyance View Post
    Nov 2019
    New Jersey
    the tightening screw pushes fluid to moveable jaw
    Aug 2015
    Illinois
    1,423
    1015
    619
    Quote Originally Posted by bruce fusello View Post
    Not quite. The screw pushes a small diameter piston into an oil-filled chamber. The large piston at the other end of the chamber pushes the operating rod that runs through the screw. I can forward the manual if you want.
