hydraulic cylinder base plate/end caps
Likes Likes:  0
Results 1 to 7 of 7
    Aug 2011
    new plymouth id
    471
    34
    115
    Default hydraulic cylinder base plate/end caps
    does anyone know of of a place that has premade hydraulic cylinder base plates/end caps with counterbalance valving already built in?
    or is that into one off stuff?
    Jul 2005
    Cottage Grove, MN 55016
    8,081
    4290
    4784
    I just cut and pasted parts of your question and came up with lots of idea's.
    "premade hydraulic cylinder base plates/end caps with counterbalance valving already built in"
    Here are a few : https://www.magisterhyd.com/custom-oem/ End Caps | Hydraulic Cylinders, Inc. Custom Hydraulic Cylinder End Caps w- Integrated Directional Control Valve Cartridge
    Dec 2012
    AUSTRALIA
    3,599
    15
    1250
    Square section tierod cylinder w/- cast ends ,no problemo ......what counterbalance valving is ,needs to be defined .....hose burst protection?.....free extend/resist return valving?......seems its a lot easier to add valving to the exterior via threaded/bolted ports......I prefer to go all steel ,welded together,rod gland end retained by a circlip,or split collets for more load capacity.Lotsa ways to do hydraulic cylinders.
    Jan 2008
    New Hampshire
    283
    135
    77
    Aggressive Hydraulics makes complete cylinders with valve cartridges and individual components. I think they would be you best bet short of you purchasing the proper form tool from Sun Hydraulics.
    Custom Hydraulic Cylinder Manufacturing
    Aug 2011
    new plymouth id
    471
    34
    115
    I was looking at form tools for what I need (just because) the one thing i was worried about is holding the tooling, wondering if holding it in a morse drill driver would be accurate enough to drill it on a lathe and face plate. Is there a place to rent form tools like there is for chamber reamers?
    Jan 2008
    New Hampshire
    283
    135
    77
    Not heard of any place renting them.
    Sep 2012
    NW Iowa
    271
    151
    209
    Should be able to buy aftermarket T-11A or T-2a tooling cheap enough.
