idacal
Hot Rolled
- Aug 9, 2011
- new plymouth id
I destroyed a barrel and rod late last week on a piece of equipment and Im trying to get it back together again for monday. I was able to get new barrel material and new rod material and got the rod built. but Im having issues finding the tolerances for the piston to barrel, and the threaded in gland to barrel tolerance. the gland has about a 1/2" length then an o ring groove another 1/2" then the threads start. im trying to reuse the gland and piston but the piston may be destroyed its a 5" cylinder with a 3" rod 56" long. 2200 psi. it looks like the piston sealing was a white nylon? ring with 2 3/4" wear rings beside it.
also is there any books that help figuring tolerances on this kind of stuff? I have searched online but nothing makes sense
