Lanza
- Jun 22, 2007
- Western Australia
Is there any specifications chart on the shaft size to piston bore clearance. The piston bore has the triangular groove for an oring. I've been using h9 on the shafts. Reason I'm asking is because some of the shafts I get are more the h11 tolerance.
I have attached a rough sketch.
The parker handbook PG101 list the triangular chamfer, id say it would be the 3/32" CS oring size.
PG89 list the diametral clearance for the static seal glands.
https://www.parker.com/Literature/O-Ring Division Literature/ORD 5700.pdf
