Hydraulic cylinder shaft clearance to piston
Results 1 to 7 of 7
    Jun 2007
    Western Australia
    228
    10
    9
    Default Hydraulic cylinder shaft clearance to piston
    Is there any specifications chart on the shaft size to piston bore clearance. The piston bore has the triangular groove for an oring. I've been using h9 on the shafts. Reason I'm asking is because some of the shafts I get are more the h11 tolerance.
    I have attached a rough sketch.
    The parker handbook PG101 list the triangular chamfer, id say it would be the 3/32" CS oring size.
    PG89 list the diametral clearance for the static seal glands.
    https://www.parker.com/Literature/O-...ORD%205700.pdf
    Mar 2005
    Indiana
    6,442
    2282
    2410
    Every one I've worked on has been a close slip fit. At that size I'd probably shoot for whichever tolerance level gets you to .0005"-.001" clearance.
  3. Likes BT Fabrication liked this post
    Nov 2019
    CANADA
    Ontario
    687
    1104
    167
    get as close as you can for a slip fit. most have an oring to seal it off anyways. id shoot for anything under 0.001"
    Sep 2012
    Iowa
    294
    176
    246
    .005 clearance nominal. 1.253.001 on the piston i.d. and 1.248.001 on the rod turndown. I would use a rectangular o-ring groove next to the piston rod shoulder. Easier to get the correct amount of squeeze on the o-ring. .06 radius where the rod turndown and shoulder meet. This is tried and true.
    Sep 2006
    SW Wisconsin
    762
    247
    282
    Quote Originally Posted by R. Dan View Post
    Plus one for that. ^^^^^
    Making the rod to piston tight can make a problem when the nut is tightened and burrs the piston enough to lock it to the rod. I have worked on hundreds of cyls and have seen some pistons that needed a large hammer and punch to remove, some times you can use the head as a slide hammer.
    Ed.
    Jul 2007
    Missoula Mt
    1,444
    62
    710
    size on size , heat to install...Phil
    Jun 2007
    Western Australia
    228
    10
    9
    I'd say your correct. The smaller pistons with a 1/2" shaft I'll make with less clearance.
