I am making a Little skid steer like machine and I need help with deciding what kintd of relief valves to use. Both motors do have have case drains but I am not sure if you can use the case drains as relief valves. If not should I use motor spools, (which dont seem to come standard with many economical valves that I have found online) or do I have to put doublé relief cushion valves on both motors. Any input would be appreciated. It is a low pressure system (1,500) PSI, and I am using a 4 GPM puormp and 5.9 cubic inch H series motors.
