Hydraulic operated elevator help
Results 1 to 9 of 9
    Jan 2013
    VA, USA
    300
    59
    111
    Default Hydraulic operated elevator help
    See attached photo, very interesting set up for an elevator that is operated by a hydraulic cylinder.
    The hydraulic system, pump, motor and valves are on the second floor due to the building being in a flood zone. Flood happened once back in 1972 so they moved the system upstairs.
    Elevator was installed when building was built back in mid-1950's or earlier.
    Cylinder ram is at least three stories high, that is how many floors the building has. Ram is one piece, see photo's.
    The cylinder is leaking which causes the elevator to creep down when on the first floor in its normal position. The fluid drains into a catch pan with a hose to a bucket.
    The cylinder looks to be ok except for the end as you can see in the photo there is fluid at the top and running down. That was from one use while I was there for the demonstration.
    While repairing it is beyond my capabilities, I would like to obtain information to pass on to the owner.
    ** The elevator is only used for moving furniture, no personnel at any time. **
    - When does this become a truly unsafe system. The only time it leaks is at the bottom when the elevator is at the first floor.
    - Is this a replacement of the top seal only or is it also a symptom of internal leaking at the piston seals.
    - Is there an "alternative" fix for the leaking at the top of the ram. See pics, you can see where there are wear marks.
    - Any idea of what the cost for that cylinder at three stories high. Not worried about the removal and installation, owner can set that part up. Just worried about the cylinder repair.
    Jul 2008
    Philadelphia
    1,939
    513
    444
    Seeing as know one has responded and I am not an expert on hydraulics, I will posit you this.
    There a gent that has you tube channel Adam Booth (ABom) he has several videos of him rebuilding very large pistons. I would try and reach out him for an unofficial pro opinion. If you come up dry hit me back and I'll ask my friend who used to rebuild hydro cylinders for CAT.
    Jan 2013
    VA, USA
    300
    59
    111
    Thanks for the post. I watch Abom from time to time.
    Jul 2003
    savannah, jaw-ja
    1,719
    1157
    403
    Advise the owner to call the company that made the elevator to come out and look at it. If they are not still in business, they probably got swallowed up in a merger. Big boys now are Thyssen-Krupp and Otis. Shindler, Mowbry and a few others are still around.
  5. Likes TDegenhart liked this post
    Dec 2012
    AUSTRALIA
    1,889
    9
    580
    I do have a lot of experience,and I can see a coating of oil on the ram.....so you do have a considerable leak....which you know......Is it dangerous.....no,provided non one is in the pit underneath......can it fail suddenly......possibly,if wear on the seals gets bad enough......it is far more likely to run out of oil and fail to lift...........Do you have a drawing of the cylinder........because some cylinders can have packings replaced without withdrawing the ram.......but not yours ,far as I can see.......I suspect you will have to lift the ram out of the cylinder.....a very costly job...........As the ram is 1950s,the packings will likely not be polyurethane ,which does fail completely,but things like graphited asbestos ,or leather....which just wear out.
  7. Likes dalmatiangirl61, ratbldr427 liked this post
  8. #6
    Aug 2015
    Illinois
    1,348
    971
    576
    I do not recognize the cylinder. The plunger looks like it is in good shape. You must be shutting down the hydraulic pump when the elevator is not in use otherwise the car would re-level. The packing is replaceable. Any elevator service company should be able to do the job. It involves supporting the car, then disconnecting the plunger, removing tge cylinder head and packing, replacing the packing and reinstalling the head, then reattaching the plunger to the car. This is not a job you want to tackle yourself. Let a professional do it.
  9. #7
    Jan 2013
    VA, USA
    300
    59
    111
    Quote Originally Posted by john.k View Post
    It is interesting on the old type packings and good to hear that they don't fail like newer types. That was a big concern for obvious reasons. Thanks.
    Quote Originally Posted by Illinoyance View Post
    Thanks for the info. Yes the elevator is shut down when not in use as the pump motor burnt out in the past to constant re-leveling, good catch on that. I have no interest on the job as it is beyond my scope. But I did want to provide some info the owner, so I appreciate the feedback.
    I am not interested in the job, but want to follow up with the owner and provide as much info as possible.
  10. #8
    Dec 2012
    AUSTRALIA
    1,889
    9
    580
    Knowing building owners ,I suspect the fix will involve partial lift removal,and placement of floors in the liftwell to gain a little more rentable space.
  11. #9
    Aug 2015
    Illinois
    1,348
    971
    576
    The packing used in hydraulic elevators is designed to leave an oil film on the plunger. That avoids chatter at low speeds.
