Hydraulic Part Identification / function help
Likes Likes:  0
Results 1 to 13 of 13
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    Default Hydraulic Part Identification / function help
    I have this hydraulic unit, only marking is marathon motor and vesco cap. I think it's a vesco vari pak, but that just describes the tank, not the functional parts.
    Anyway, looking at the relief valve/valve block/gauge, can anyone explain what the two ports coming out the top are for? The one on the left seems to be outlet, the one on the right possibly return to tank? I am guessing that only because it's situated on the same side as the relief valve. There don't seem to be any identifying numbers.
    Right now I am having trouble getting unit to work when connected to a center closed valve (it stalls after moving cylinder to maximum position, so I'm assuming relief valve isn't opening?). It circulates fine without load attached. I have backed out the relief valve thinking it might have been wound in too tight.
    I am also not getting any pressure reading on the gauge, even when it stalls the motor.
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    I think that's just the pump compensator valve, and I need a directional valve with built in pressure relief. Does open center/closed center matter in terms of the directional valve? I just want to make a cylinder move in and out.
    May 2006
    Seattle
    2,298
    56
    564
    I'm guessing the pump is in the tank.
    I suggest you remove that valve and take it apart. It shouldn't be difficult or complicated. Once apart, you will likely understand how it works and what it does, or at least find some numbers you can look up.
    metalmagpie
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    Yes, pump is in the tank.
    I will probably end up doing that...because it seems that even if it is a compensator, which I no longer think it is, it should still display a pressure on the gauge, and it should also kick the oil out, unless the pressure is set higher than the pump is capable providing.
    i hate hydraulics
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    Finally backed the relief all the way out, hoping it would come out, which it didn't. Anyway, when I did that, I was able to start the pump, but it sounds like it's cavitating. Upon starting, I can screw the relief back in until about 250 PSI, then it stalls.
    So I need to take the whole thing apart and see if it has enough oil in it (I think it's a submerged pump, but I'm not sure). If not that, hope that installing an open center valve will provide enough flow to keep the pump primed, and not cavitating...and if that doesn't work, probably replace the pump...or the motor, who knows.
    Jan 2007
    wales.uk
    1,361
    214
    251
    Looks a bypass valve
    Mark
    Jun 2013
    Northern Il
    1,571
    801
    1437
    Quote Originally Posted by snowman View Post
    Is the pump/motor direction correct?
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    Quote Originally Posted by Ziggy2 View Post
    Yes. 110 volt, but already checked that.
    Aug 2011
    new plymouth id
    472
    34
    116
    not a lot of pictures of the hosing but I don't think they would use a closed circuit system (that's a variable flow pump very expensive) on a basic power power pack you probably need an open center valve and some way for the oil to return to tank
    that may have been built to run a hydraulic motor one direction, turn it on, run your motor turn it off. jmo need an open center valve and a dump port in the tank but more pictures of the full unit would help
    I wouldn't think you want it hitting the relief except for momentarily.
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    Quote Originally Posted by idacal View Post
    Thank you...that is what I thought, but don’t have enough experience with hydraulics to really know for sure.
    Is it reasonable to think that the 250 psi relief valve problem where it won’t go above that, is likely to go away once I have an open center valve that allows the pump to fully prime?
  11. #11
    Aug 2011
    new plymouth id
    472
    34
    116
    I tried to find an easy to watch youtube that makes sense. Probably look up woodsplitter hydraulic systems. they would make the most sense. Personally I cant follow written diagrams, Have to se it work. Basicly an open center system is a pump that flows to a valve a relief on the pressure side in the system then back to the tank. When the valve is kicked it sends the oil to the cylinder while the oil on the other side of the cylinder runs back through the valve into the filter then into the tank. I think its a 4 way 3 position valve is what is needed. Dont know if this makes sense
  12. #12
    Jun 2006
    Kansas
    1,565
    302
    592
    You need an open center control valve, some valves can be converter from open center to closed center by changing a plug.
    Tell us more what you are trying to do, and more photos of plumbing.
    You should be able to get way more than 250PSI before stalling the motor.
    You have a sight gauge to check oil level.
    Return from open center should go through the oil filter.
  13. #13
    Jul 2004
    Southeast Michigan
    6,904
    274
    1726
    It's going in to a closed center valve with only one solenoid, so opening it up would never retract the cylinder.
    I think I've got a small pile of hydraulic stuff at my other shop. That's my biggest detractor on stuff like this, is I don't have the parts to just "play".
