So I have a very well built homemade hydraulic press that my grandfather purchased around late 1940s. The hydraulic pump has gotten very weak and needs to be replaced. It is an old Racine military surplus pump and no info on it is available that I have found so I would like to calculate what I could replace it with. Shaft size is 1" but I could always replace the half of my Lovejoy for a smaller shaft size. I do also have a couple of 5 hp motors but they are pretty much the same rpm.
My Ram is 2 3/8" dia. in a 6" dia. casing which is just over 32" long. My motor is a 3 phase 7.5 hp 1725 rpm. I would like to run at least 10 ton but maybe more if my setup would handle it.
I am mainly using it to bend 1 1/4" pipe but use it to press out bearings and straighten bent metal also. I have pics but do not know how to post them. Was looking at a Vickers or Eaton style pump. Also not sure if I should get a vane or gear pump.
