Hydraulic U seal installation info needed...for starters, "pre tension element" ??
Single acting pancake cylinder (releases drawbar on VMC)... the original seals were so deterioated they basically fell apart during removal so I wonder about two things before installing the new seals -
1. As there was no "pre tension element" (simply an 0 ring ?...see 2:07 in below video ) in the original setup, should I perhaps add one now, regardless ? I did think it odd that the ID where the seals mount, is larger than the OD of the seal. So now I wonder if the pre tension element was left out and that is the reason the seals failed ??
2. As the original seals were toast it didn't occur to me to pay attention to the orientation as I removed the remnants... should the seal lip angle toward the pressure, or away from it ? The video at 4:32 would indicate that the lip angles toward the pressure...which makes logical sense...but just to be sure, you tell me.
