ratbldr427
Titanium
- Mar 21, 2006
- jacksonville,fl.
Anybody here make valve bodys for cartridge valves?
I need what seemed to be a simple valve body but can't find it listed as stock anywhere.
What I want is a body that has two #8 ports(o'ring or NPT) in the top going through a NC solenoid cartridge.Opposite side I want another cartridge cavity same as the top to insert a cartridge needle valve,no check valves,need bi-directional flow.I want some 3/8" or smaller holes drilled & crossed drilled connecting the upper ports to the lower needle valve.
The flow would be across the needle when the upper valve is closed and parallel across both when open.
I am trying to get a creep feed on two cylinders when a prox sensor sees either of two targets.We have two machines that were built without cushioned cylinders and due to the design I can't install cushioned cylinders because the length would be to long with the same stroke.
I have already modified one machine but used two proxes and some plumbing to use two cartridge valves paralleled across the two existing flow controls installed at the directional valve.
Works great however I want to simplify every thing and this will work just as well.I could buy the porting tool and make it myself but I would rather buy a valve body.Prefer steel but can be aluminum.
