Hi Experts,
I am looking to build a forging press for home based projects. I have all of the designs done but I am having an issue with the hydraulics, specifically what type of pump and motor combination would work. I have settled on a Tie Rod cylinder 4 inch bore with a 10 inch stroke 2 inch diameter Rod. This cylinder can do 3000 PSI. My requirement is to run this cylinder on an electric motor, i prefer standard 110v power but can wire 220v if needed. For my application research shows that 13GPM pump should be enough to run the press.
Below are links to the pump and motor combo I am looking at. Can anyone tell me if this setup would work for the cylinder I have chosen. I totally understand that different selections can change the overall performance of the setup. I am really looking for a check that I am not way off in left field with this setup.
13 GPM GEAR PUMP & 25 GPM VALVE COMBO KIT - Pumps - Parts | RuggedMade.
Shop Tools and Machinery at Grizzly.com
Any thoughts or suggestions on the setup are greatly appreciated. I have also included a picture of a CAD drawling in case that would help anyone with my question.
Imgur: The magic of the Internet
Mark
Mark
