JasonPAtkins
Hot Rolled
- Sep 30, 2010
- Guinea-Bissau, West Africa
My Colchester lathe didn't come with the spindle nose bush that allows a center to be mounted in the spindle. I very carefully indicated the compound against the spindle nose, cut the bush, then sandpapered it nice and smooth. To check the fit, I put layout blue on the part as I've read to do, and then shoved it in and popped it out a couple of times.
Now, I can't tell what the results mean. The lathe is old and the spindle nose has a fair number of burrs inside it. I can pretty clearly see those in the blueing, but other than that I'm not seeing much. Here are the pics:
After those were taken, I put it back in and drilled a 1/4" pilot and then a 1" hole (with twist drills) to prepare for boring the MT4 socket. With heavy drilling feed - the bush didn't spin against the spindle nose, which to me says the taper must be grabbing pretty well, as it didn't appear to move at all under some pretty serious twisting pressure from the bit. I can envision though, that theoretically it would still be possible for my taper to be off and the bush is grabbing just the front or just the back of the spindle nose, thus might be able to be forced out of alignment (i.e. pitching its nose up or down) under heavy cutting pressure.
After the drilling operation, the blueing was showing some more rubbing.
Indicating the compound against the spindle nose, I got the error down to .001" in a 1.5" sweep with a bestest DTI before cutting the taper. So, I want to believe it worked out just like I planned and I got a perfectly mated taper - but I'm a rookie at cutting tapers AND reading the blueing for fit, so I'd like some confirmation, or help on what specifically to look for to understand what the blueing is telling me.
