I Lost my 60 Tooth Gear for my Vintage Logan 14 In. 6560 H Lathe & Need a New Gear !
Hello All, My Keyboard is messed up and can't indent the paragraphs, so bear with me. I bought a Logan 14 In. Lathe (6560 H) about 3 or 4 years ago. I did not have 3 Phase power & tight on room & it's set all this time. I did check it out and found that the 60 Tooth Gear was worn quite a bit on the 5/8 In. bushing, guessing about .006 to .009 inches of wear. The other gears were not nearly as worn and I did not worry about them. Anyway, I removed the gear and have laid it somewhere. I have spent two full days hunting it and have gave up. I'm sure that it will turn up, that's after I buy a new one. .................... Now, I have priced it at Logan and it's around $ 297.00 or so. I have found it on fbay for about 1/2 this amount & used. I talked to my best friend from high school that's a retired tool & die maker. He said, if you send it to me; I'll make it and send it back to you the next day. I replied, I lost it and can't send it out. He said, OK, send me the OD, ID, Gear Width, is it keyed or not & key size. Check depth of the gear tooth that it runs with (top of gear to bottom of vee). I can go to the Gear Cutting Chart and Find it's Specs. & reproduce it. Also, it will be a 14.5 or 20.0 tooth angle. ............. So, can anyone give me the spec's for their -- 60 tooth gear, the OD ______ Dia. & Gear Width ? I know the ID for the shaft is 5/8 (.625 I can measure the other gears that it runs with to get the Tooth Depth. Thanks in Advance, Avery
