I need an alternate solution to scotch brite pads when wiping down barstock.
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Mar 2019
    Massachusetts
    533
    246
    236
    Default I need an alternate solution to scotch brite pads when wiping down barstock.
    I have a job coming up that uses .250" round 303 SS. Long parts, runs 12' in 5 min. I had 365 lengths last time and I had to really scrub them down with the pads to get all of the oil/grease off of them. This is very tedious and hurts the hands quickly.
    Any little bit of leftover grease spots causes the part to not feed out correctly. They get hung up in the feed finger (rubber). Long parts with expensive material means I cannot afford to scrap a lot.
    I had the employee prepping about 60-75 bars every morning for me last time and it took over an hour. Not all of the bars are 100% after 1 person hits it with the scotch brite pads either.
    I feel like I should be able to attach something to a cordless drill to use like a de-barker for logs. Or any type of cordless tool for that matter. Sander maybe? I have seen cordless sanders before, but how would I go about this. Something I can feed the 12' bar through to clean up the surface prior to machining.
    There has to be an easier/more efficient way.
    Jun 2008
    TN
    1,814
    566
    407
    Cheap pressure washer or steam cleaner?
    Feb 2006
    Indiana
    14,091
    826
    4820
    I have not bought stainless bar for a long time, but what I bought arrived perfectly clean. Maybe you should ask your supplier about cleaning before shipping, or ask other suppliers.
    Larry
  4. Likes rpseguin, gary-sc liked this post
    Jun 2019
    South Dakota
    146
    41
    51
    If it's grease and dirt, no marks or scale, perhaps a hot pressure washer. Available by rental, and work quick on grease and dirt if you have a concrete pad to clean em on.
    Mar 2011
    SWITZERLAND
    1,176
    149
    471
    Got a conventional lathe? Remove tailstock, mount internal brush, shove bars through. Something like that Internal ring brush - Waldo Brush
    Cleaning fluid, perfect preparation
    Mar 2019
    Massachusetts
    533
    246
    236
    Quote Originally Posted by Mechanola View Post
    Now this is what I was thinking of. If I can hold it in the collet somehow, I could feed bars right through it.
    I was thinking more like a wire brush for cleaning the ends of copper piping that I could somehow spin while feeding the barstock through.
    Mar 2019
    Massachusetts
    533
    246
    236
    Quote Originally Posted by L Vanice View Post
    Larry
    Cold Drawn material (303). It is flooded as is it drawn through a die. The oil stays on the material and as it dries up it gets tacky and greasy.
    Other stainless I get is ground to size and comes in clean. 316L comes in clean all the time.
  9. Likes plastikdreams liked this post
  10. #8
    Mar 2019
    Massachusetts
    533
    246
    236
    Quote Originally Posted by hvnlymachining View Post
    I cant imagine spraying water on anything in my shop. Water is the devil around here. It ruins everything. How would I go about disposing of all bad fluids after? And keeping it all contained.
    Sounds like opening another can of worms.
  11. #9
    Mar 2019
    Massachusetts
    533
    246
    236
    https://www.homedepot.com/p/HDX-1-2-...-111/204258910
    I like this idea. Although I think the finish wouldnt be nice afterwards.
  12. #10
    Sep 2002
    People's Republic
    6,572
    774
    3898
    I am wondering if pretreatment with whatever will thin/dissolve the oil will cut the work/time involved. Simple green, WD....
    Build a trough to throw x number in and soak. then wipe down after x minutes, while the next batch is soaking. PVC pipe is cheapity cheap. zipped in half lengthwise to make a tray....glue some overlapping sections to make it long enough......
    If you got the process down the only waste would be rags etc rather than liquid waste
  13. Likes SAG 180 liked this post
  14. #11
    Mar 2009
    Brunswick Oh USA
    4,809
    5722
    2924
    Those are for cleaning copper tube which is usually 5/8 & 7/8 OD. and not made for .250 round. Plus they aren't worth two dead flies anyway.
  15. Likes Marty Feldman liked this post
  16. #12
    Mar 2005
    Kansas
    8,775
    630
    4505
    Not anymore, its become stupid expensive, if you can find what you need. For example I needed 3" conduit. Quote was $7.00/ft, with none in stock.
  17. Likes true temper liked this post
  18. #13
    Feb 2007
    St. George, Utah
    1,477
    993
    1033
    Cleaning large quantities of 304 round is a regular job for us. We run the 12' bars through a tumbler cycle with degreaser and rinse, then a quick wipedown and they're ready to go.
  19. #14
    Mar 2019
    Massachusetts
    533
    246
    236
    Quote Originally Posted by Gordon Heaton View Post
    Now there is an idea. I will look into this, in the long run this could be like 500 lengths every 3 months.
    So far its been the scotch brite style pads with a dip in kerosene. Works great when you only need 1 bar ever 2 hours. Not 12 an hour.
  20. #15
    Oct 2005
    22,764
    Quote Originally Posted by DanASM View Post
    Dynabrade makes an air powered hand held belt sander for polishing hand rails, and you can get scotchbrite belts for it.
    You might make your own, with different side plates for the rollers, that put the belt with more "wrap angle" around your stock.
    Dynabrade Power Tools | Made in USA
    EDIT:
    Oooh better !
    handrail pollishing belt sander at DuckDuckGo
    If you use an air motor, you can flood solvent all over it when running (into a large splash pan underneath), with no fire hazard.
  21. #16
    Mar 2019
    Massachusetts
    533
    246
    236
    EDIT:
    Oooh better !
    I like the handrail polisher. That is something I had in my head but couldnt picture ever seeing one.
    Now I can imagine a vertical belt sander like the knife guys use that I can roll the bars up against while passing the 12" through.
    Great ideas.
    I just saw this one as an attachment to a grinder. Thats more of what I had in mind for attaching to a Dewalt.
    SandPro™
  22. #17
    Sep 2005
    Oakland, CA
    3,126
    675
    1027
    Seems a cordless drill on one end and a rigged up stock stand for the other end to run in and possibly in the middle and two guys could knock out a bunch of them in short order. The bars don't have to spin real fast for what you are doing. One guy on the drill and the other with the scotch brite/ steel wool. Mount the drill on something and do it with one guy. Keep it simple!
    Gordon- most shops don't have a tumbler big enough to put 12' long bars in! Did I miss something?
  23. #18
    Mar 2019
    Massachusetts
    533
    246
    236
    I am thinking I can put the bars in the back of another hand screw machine that I have without the stock tube holding the bar.
    I can put a stock stand down towards the end and put a bushing or small piece of pvc in it to hold the bar stock in place. Might not be too safe for the employees but I know I can do it. Probably quicker with a little help.
  24. #19
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,105
    114
    989
    i'd ditch the kerosene and go with a hot T.S.P. solution from a
    HOTSY .. it will emulsify the oily shit so it can be rinsed
    with water . you could save the Kerosene to run the boiler
    on the steamer instead.
  25. Likes henrya liked this post
  26. #20
    Dec 2012
    Se Ma USA
    2,317
    186
    1273
    Bosch or Grit centerless grinder with abrasives to suit.
