I need info on building a 10,000 psi hydraulic pump
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Apr 2001
    tucson arizona usa
    5,066
    2198
    4775
    Default I need info on building a 10,000 psi hydraulic pump
    I have built all sorts of hydraulic power units for my presses, I am in the process of making a 100 ton press. I will be using an enerpac hydraulic cylinder but I would like to make the pump myself. I need to know of some suppliers for 10,000 psi pump heads. I can get the hoses and the fittings but have never tried to source any of the high pressure components. Does anyone know where to look. I have hit google and found some manufacturers but they wont sell me a pump. Who sells this stuff and how much is it.
    Aug 2005
    Tucson AZ
    6,276
    9368
    2939
    Kevin, you are entering a realm of liability that you may want to pass on to an established manufacturer. It is unlikely that you will be able to compete with the likes of Simplex or Enerpac. There are documented fatalities from hose bursts and such that are more liability than you should bear. They make the big bucks because they can bear the lawsuits.
    Apr 2001
    tucson arizona usa
    5,066
    2198
    4775
    You are probably right I just wanted to check out the options. I build my own low pressure pumps and have saved over a 1000 dollars on each pump by making them myself. I should probably stay out of the high pressure stuff.
    Mar 2009
    Eureka, CA
    3,708
    730
    1261
    Power Team makes a air-over-hydraulic 10,000 psi unit for under $400 bucks. I have one and they're pretty cool...seems like it would be much easier to purchase than to build. Maybe the GPM is to small for your job?
    Stuart
  5. Likes oldbikerdude37 liked this post
    Oct 2005
    14,531
    star makes just the head, that go to 10ksi, the threaded model only goes to 5k though.
    Custom Hydraulic Pumps and Cylinders - Star Hydraulics, LLC - River Grove, IL
    Apr 2001
    tucson arizona usa
    5,066
    2198
    4775
    Have any of you ever seen someone put a motor on a manual pump. I have been thinking about putting a motor on the pump instead of a handle.
    Oct 2003
    East Peoria, IL, USA
    5,384
    336
    786
    I have a 220v powerteam pump, like new. (ok used a couple of running hours over the course of a job) to sell.
    it runs double or single sided cylinders.
    has 2 speed pump, (moves the cyl faster untill it loads up then it relieves to lower flow at high pressure)
    hand control on-button pendant.
    this is it except my motor is for 220v
    Ohio Power Tool - Power Team Electric Hydraulic Pump - Double Acting PE554
    For the job it was purchased and used on it was perfect, but for my general use on my own smaller 20 ton press it is way to fast so it has sat in it's box all lonely and dejected. I like a foot treadle controlled air over hydraulic unit for my small press better. This belongs on a big press. I want $2k for it.
  9. #8
    Oct 2005
    14,531
    Quote Originally Posted by kpotter View Post
    Yup, the H.F. bottle jack runs an air cylinder to pump the piston.
    http://www.harborfreight.com/20-ton-...9593-8979.html
    They work nice, put one on my 20 ton press, they still retained the hand pump,
    so I can hand pump the last little bit, and feel a bearing coming up to a shoulder.
  10. #9
    Oct 2003
    5,384
    336
    786
    Yup, the H.F. bottle jack run an air cylinder to pump the piston.
    so I can feel a bearing coming up to a shoulder.
    I dont get how that works? but I do have a manifold on my system that allows me to feed it from a hand pump or the air motor pump. I just have to remember to let oil the back into the correct pump when releasing because they have seperate resevoirs.
  11. #10
    Nov 2004
    Utah
    7
    Did you ever find a supplier or build a unit?
  12. #11
    Jan 2007
    Annapolis, Maryland
    530
    744
    288
    There's a few small companies that make very high pressure pumps that run off compressed air. They are slow but deliver high fluid pressure. There is a name for them that evades me now, but with some research... All stop...
    Haskel pump. Check them out. Very simple device. Again, low volume, but can do the pressure. You might be able to couple these with a lower pressure pump to get the press to a certain point, then switch over.
  13. #12
    Jan 2007
    Annapolis, Maryland
    530
    744
    288
  14. #13
    Feb 2005
    Owl's Head, Maine
    2,209
    351
    592
    44 Not Found
    bad link: "We couldn't find that page or address"
    -Marty-
  15. #14
    Feb 2005
    Owl's Head, Maine
    2,209
    351
    592
    44 Not Found
    -Marty-
  16. #15
    Feb 2005
    Owl's Head, Maine
    2,209
    351
    592
    44 Not Found
    bad link: "We couldn't find that page or address". Being HF, may be just as well.
    -Marty-
    -Marty-
  17. #16
    Feb 2005
    Owl's Head, Maine
    2,209
    351
    592
    44 Not Found
    -Marty-
  18. #17
    Oct 2009
    Oregon
    4,074
    4378
    2049
    Quote Originally Posted by Antarctica View Post
    they are called intensifiers. Air/air, air/hydraulic, hydraulic/hydraulic.
  19. Likes digger doug, Djstorm100, Farmer Phil liked this post
  20. #18
    Jan 2005
    Victoria, Texas, USA
    3,921
    2013
    952
    Depending on the volumn you are trying to pump, They do make high pressure triplex pumps, can't think of a specific brand, they are out there. Haskel does make several air over hydraulic that are ball check operated that can handle pressures up over 30K and I've used these before, too for pumping oil.
  21. Likes Djstorm100 liked this post
  22. #19
    Oct 2005
    14,531
    I think Mr Potter fingered it out 4 years ago.....
  23. #20
    Jul 2014
    Raleigh NC
    121
    29
    6
    Just saw the OP date.
