I want to make a handle from rectangular tubing where one pc fits into another.
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Apr 2014
    Iowa
    11
    Default I want to make a handle from rectangular tubing where one pc fits into another.
    As the title explains, I have a 3/4 x 1 1/2 14 ga tube and I want to make a two pc handle for shipping purposes. I want to squeeze or compress the end of the tube so that it fits into the other handle to create a longer handle. Is the a machine or something that can compress about 6-8 inches so that one end would fit snugly into the other?
    Thanks for any ideas.
    Kyle
    Apr 2004
    Modesto, CA USA
    8,545
    1632
    Why not just use two sizes of tube that nest together?
    Bill D
  3. Likes Illinoyance liked this post
    Oct 2005
    21,705
    Quote Originally Posted by ksp View Post
    Kyle
    Try finn power:
    Finn-Power Crimping Machine Applications | Lillbacka USA | Finn-Power
    For lower qty's, try a short insert, and drill some holes in one tube, plug weld the insert in.
    May 2006
    Seattle
    2,488
    62
    649
    What if you made up a rectangular mandrel and then used a hydraulic press to squish the tube OD down hard to the mandrel? The mandrel would prevent the tube from deforming too far. Crush it some on sides A and C then rotate 90 degrees and do sides B and D.
    Red heat would make it easier.
    metalmagpie
    Jan 2005
    The Netherlands
    6,696
    367
    1943
    Always the same question
    Howmany ???
    10 10000 or 1000000 makes a huge difference
    Peter
  7. Likes Illinoyance, bosleyjr liked this post
  8. #6
    Dec 2012
    Se Ma USA
    2,198
    179
    1198
    Squish one to fit into other, or stretch one so other fits inside.
  9. #7
    Jul 2006
    Hillsboro, New Hampshire
    13,054
    2947
    8964
    Quote Originally Posted by Scruffy887 View Post
    Thatswhatshesaid...
  10. #8
    Apr 2020
    1,268
    1106
    459
    Thatswhatshesaid...
    That’s how you liberals have sex? No wonder you cuck olds are always so frustrated
  11. #9
    Apr 2014
    Iowa
    11
    Thanks for all the replies, even the last few LOL.
    This will be an ongoing process in which I am trying to save on shipping of a product by shortening the packaging to under 48" to avoid over dimension charges. The customer would have to put the two handle parts together securely as it is a lifting handle. Either compressing one part or swaging the other would work and I intend for a bolt to hold the parts together. At this time I am doing about 1500 of these a year so not a lot but still need a decent wat to accomplish this as it would save $14 per shipment. I do have an Edwards 55 ton ironworkwe with the acc press which would work if I could get the right dies to compress the tube to fit inside the other tube. Is there someone who can suggest a company that could make that die?
  12. #10
    Apr 2014
    Iowa
    11
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    Interesting, I may play around with that. I am wondering how side a and c will react when you start compressing b and d.
  13. #11
    Jan 2004
    Halifax Nova Scotia
    1,831
    5
    275
    Even if you are able to successfully stage one of the tubes you will likely still have issues getting then to nest. square tube usually has a weld seem down one side and on the inside the weld will have to be removed flush to the surface befor the tubes can be nested
  14. #12
    Apr 2014
    Iowa
    11
    Quote Originally Posted by Frederick Harvie View Post
    True, but I could try and over compress a little to make it work and I have seen examples where the end of the tube is crimped so that it may not be an issue.
  15. #13
    Jan 2002
    West Coast, USA
    9,152
    603
    6670
    Curious why you want nested rectangular tubing, with a slip fit? Round tubing with a spring-pin or clutch retainer is commonly used (from metal crutches and tripods to patio umbrellas and garden tools) because it's cheap, readily available in nested sizes, and can be rotated free if something galls a bit. Threaded connections can be even more solid.
    Not so easy or cheap with square or rectangular tube. It's more likely IMO to be either loose (those welded seams) or eventually jam up.
    Assuming the rectangular handle form is necessary for function, another approach is to have a mating tenon and some sort of ball pin, etc. to attach and detach.
  16. #14
    Oct 2005
    21,705
    If you make an insert (to plug weld into one of the pieces) and it extends out to be installed inside the other tube by the customer (and help with bolts) you could make that from sheet metal,
    and leave a small portion out (a slot the full length), for the tube's weld.
    It would look like a "C", and plug welds would be on all 4 sides, pulling the insert out, ensuring a tight fit.
  17. #15
    Apr 2014
    Iowa
    11
    Quote Originally Posted by PeteM View Post
    Has to be rectangular tube per design so I am stuck on that. My plan is to create a slip joint that would need to be tapped tight with a hammer and then a bolt through both pcs to keep tight.
  18. #16
    Apr 2014
    Iowa
    11
    Yes I was mulling over a plug insert and if I had the ability to make that I might consider it but it has to be very strong as it is used as a handle to lift heavy items so that connection has to be very stout.
  19. #17
    Sep 2006
    SE PA, Philly
    5,603
    1128
    2066
    I can't recall where I was, but in the last few days I saw a wheelbarrow with square metal tubing. About 1.5x1.5 inch. The handle area had been scrunched down someone like what you are shooting for.
    If you just have a few, I'd chisel off the inside weld and put a short section of smaller tube in one side of the connection. Screw or plug weld it in.
    If you have kajillions (like if this is for a consumer product) then the added time to figure out and optimize tooling to scrunce the thing might be worth it.
    Other guys know more about that then I do, but would it be possible to scrunch in one direction, then rotate 90° to get both sides scrunched? Still have to chisel or use a file belt sander to get rid of the weld...
  20. #18
    Mar 2009
    6,119
    116
    1201
    I would use a rectangular tubing on one side a then machine a solid square bar. It can be cut down to fit the square hole as tight as you want. Make it out of aluminum.
    If the solid square piece is too heavy then it can be drilled through. A square piece with a round hole inside. Nobody will know except you.
  21. Likes sfriedberg liked this post
  22. #19
    Jul 2004
    Houston, TX USA
    32,132
    Quote Originally Posted by rons View Post
    Plus one here - don't worry about inside weld - find out where it is and mill a groove for it in the insert.
  23. #20
    Aug 2012
    California, Central Coast
    5,235
    2385
    2159
    It might be easier to overbend the flats so they are all concave, leaving the four corners to align the tubes. The weld seams are going to a little random from tube to tube so if the flats were concave in it would not matter where the seam was. Also that would be a little easier to do not having to upset all the material, some would be bent in.
