Hi all, I'm requesting your experience or ideas in practically shortening some high tensile anchor rods in concrete.
Anchor Rod Specs: 1-1/4"-7 tpi, High Tensile, Galvanized.
Situation is that about 80 to 100 anchor rods have been damaged and we need to cut them off flush with the concrete, core drill down around the anchor maybe 6 inches deep with an approximate 4" diameter hole, break out the concrete and then install a coupling nut on the good threads below top of concrete (TOC). Some of the rods are damaged a bit below TOC so they need to be cut off in the hole.
Once all rods are cut to a suitable length exposing undamaged anchor rod we need to chase the threads to remove bits of leftover concrete, a plan is in place for that.
Ideas include a mag drill with a center drilling type endmill but I'm not sure the mag drill is suitable for driving endmills. (I know concrete isn't magnetic, we will worry about mounting it)
What other tools or technologies can get in the hole and create a finished end on the top of the anchor rod?
Maybe there is a company that specializes in this repair?
I've seen the AISC field repair manuals etc so no need to post them.
Thanks, Chris
Thanks, Chris
