Ideas for workholding / fixture please!
Results 1 to 18 of 18
    Sep 2021
    NETHERLANDS
    12
    Default Ideas for workholding / fixture please!
    Hi all,
    First post for me, so Hi again!
    I'm running out of ideas for a fixture/workholding of a part.
    In this part I need to mill three 'bayonet lockings'(?), 120 degrees apart (at the circumference).
    The part dimensions are Ø170mm (6.7") by 85mm (3,4"), I added a picture also.
    Now the question is what do you think is the best fixture for this part, I need to make 50 of them.
    Hope to hear from you,
    Coert
    Attached Thumbnails Attached Thumbnails whatsapp-image-2021-09-16-08.48.28.jpg
    Sep 2004
    Wisconsin
    276
    75
    Is it hollow? 3 jaw chuck internal grip mounted on rotary table. Bolt to mill table so chuck is horizontal.
  3. Likes Illinoyance liked this post
    Sep 2021
    NETHERLANDS
    12
    Thanks for the reply.
    Yes it's hollow with a wall thickness of 2mm.
    Your option is one of the options, but the minimal wall thickness is a bit of a problem I think. A 6-jaw chuck would be better, but unfortunately we don't have that.
    An extra option with this solution is to use a tailstock with a delrin ring.
    Feb 2007
    Aberdeen, UK
    4,768
    1765
    2333
    Make a spider that fits inside, put in three jaw chuck clamping on the spider so the chuck does not collapse the part. Machine the bayonets between the jaws.
  6. Likes AARONT, Dan from Oakland, doug925 liked this post
  7. #5
    Jan 2007
    wales.uk
    1,887
    427
    448
    Vacuum Chuck suggests itself,
    Mark
  8. #6
    Virginia
    21,201
    7561
    12385
    Quote Originally Posted by CoertHFT View Post
    Punch it then. That's how this sort of goods are usually done for volume production.
    Simply support the hollow rim on a curved arc of a shoe, mating pair of arced shoes....or even rollers.
    The section of it you need to work on is functionally the same as a 2 mm wall tube, the closed "spinner" part of the shape is not involved.
    Or mill it, but same deal. You don't NEED to grip the entire part and spin it.
    Only grip and reinforce the rim where the cutting force is to be applied.
    Shouldn't be rocket science to index off the first slot cut?
    "Worried?" Go to the delron form (or shiney-wood) concept - and rig it for internal expander WITH an external "cinch" band, too. All you need is a narrow cylinder. External band needs cut-outs, Internal should have clearance pockets as well.
    Mating clamping so you neither stretch nor shrink it.
  9. #7
    Sep 2021
    NETHERLANDS
    12
    Quote Originally Posted by gregormarwick View Post
    That's a possibility for sure. Thank you!
  10. #8
    Sep 2021
    NETHERLANDS
    12
    Quote Originally Posted by boslab View Post
    Mark
    Thanks for your suggestion. We have a vacuum chuck already but the part does not stay perpendicular to the machine axis. Already tried to correct it with a corner plate, but it doesn't work.
  11. #9
    Sep 2021
    NETHERLANDS
    12
    Thanks for your idea. Punching isn't one of the possibility's since we don't have punching machines.
    I don't really get your last idea, it is pretty stiff to compress
  12. #10
    Dec 2019
    AUSTRALIA
    79
    19
    Make an acetal or ply disk 1" thick that fits the ID. 3 jaw chuck from the outside on a rotary table?
  13. #11
    Sep 2021
    NETHERLANDS
    12
    Quote Originally Posted by NewGunPlumber View Post
    I think you both mean the same. That's what I'm going to try now. Thank you very much!
  14. #12
    Virginia
    21,201
    7561
    12385
    You don't want to distort it. You want to grip it with balanced force.
    If the only workholder you have is a 3-Jaw?
    You first make an internal plug for the jaws to work against.
    And rigid, not resilient. Adjustable with a skosh of expansion, even.
    This is not a new challenge.
    Put yourself in the shoes of an ancient armorer making helms and riveted features for battles when "high tech weaponry" was still Bronze swords and a whole army had to be equipped, faster and better than the other side.
  15. #13
    Oct 2009
    Louisville, KY, USA
    1,193
    224
    327
    Sounds like you're recommending a hammer and chisel. 😜
  16. Likes charlie gary liked this post
  17. #14
    Jan 2007
    wales.uk
    1,887
    427
    448
    Dividing head, with ring, foot stock with ball, do it between centres, you might have to plug the middle with timber or uhw to stop chattery resonance, assuming vertical mill to cut the bayonet slots, reminds me of a Harley pan head headlight I once repaired ( rust ) that had the same bayonet slots, if it was original I don’t know, the metal spinning my mother in law worked used similar “ cup and ball” fixturing on round bowls
    Mark
  18. #15
    Virginia
    21,201
    7561
    12385
    Quote Originally Posted by fciron View Post
    Sounds like you're recommending a hammer and chisel. ��
    'Observing", rather than recommending. But they work just fine if you know your s**t.
    https://www.metmuseum.org/toah/hd/deca/hd_deca.htm
    Hydraulic nibbler is faster.
  19. #16
    Nov 2013
    Eastern Massachusetts, USA
    7,648
    6312
    6805
    Is the part a stamping/pressing (ie hollow)?
    If so, I'm thinking sacrificial soft jaws on a chuck, turned to the ID, on a simple indexing fixture. Mill slightly into the jaws with a larger diameter first, then mount the parts and mill them.
  20. #17
    Oct 2009
    Washington
    1,537
    1103
    850
    Am I the only one curious about what kind of machine he's got to do the work? If it's a vertical mill, you could get away with making a triangle plate that has a round protrusion that fit inside the part. Set up an angle plate on the mill, clamp the part/fixture plate against the angle plate with the fixture sitting on one of the three triangle flats and mill your feature. Turn it to the next flat for the next feature. Repeat until done.
  21. #18
    Feb 2020
    Maryland
    273
    108
    You don't tell us what machines you have to work with. In my shop I would use my Bridgeport right angle adapter and a rotary table.
    To fixture it on the rotary table I would use a sacrificial round piece of aluminum plate slightly larger in diameter than the open end of the work piece. To that piece attach another sacrificial round piece of aluminum plate exactly the inside diameter of the work piece. Then you can clamp down from the bullet nose end of the work piece. The bottom aluminum plate would have to be very thick or spaced high enough above the top of the rotary table to avoid interference with the right angle head.
