I need to cut some splines on a driveshaft.
I bought a cutter so I can cut them in one go (DIN 5481). But the angle of the splines is bigger.
I can cut the splines on some test pieces with the DIN5481 cutter and use multiple passes to get the right angle.
But I prefer to cut them in one pass.
Are there some standard sizes for drive shaft splines or a good way to identify them?
