I'm 6'4" and I recently acquired a Kingston HJ-1700. With the machine setting at normal height, I'm bent over in an uncomfortable position to reach the controls, and I'd like to raise it about 6". This is a semi-permanent installation, it might be there for a year, or 15. The simplest solution seems to be pouring some thick concrete pads on the floor under each end and then leveling the machine out on top of them, but that might be a little more permanent than I like. The other option would be to bolt some heavy square tubing to the bottom of the pedastals and relocate the jack screws to the bottom of them before leveling.
I'm certainly not the first person to run into this problem, has any body seen any clever solutions?
