JohnEvans
Titanium
- Sep 23, 2009
- Phoenix,AZ
Ordered in some 12L14 to make a hub to adapt a Chevy V-8 crank vibabration dampner to a Hot Roded Modle A Ford 4 banger for a friend. Drilled a through hole and bored to size ,turned the 2 dia. on the OD and parted off. The boring cuts were smooth and quiet,didn't notice the issue until after I milled a keyway on the small OD. The inclusion looks like a piece of 3/16 tool stock went into the melt and had a higher melting point so stayed intact. The damage will not affect the use and being it's for a friend he won't care. A regular customer would not be so understanding I fear. The only good thing is that it is on the ID ,on the OD being it's leaded steel I could not build up with weld. NUTS!!!!!
