black69wolf69
- Apr 9, 2012
- Khanh Hoa, Vietnam
Hi,
I am in charge of the induction heat treatment machine at my company and since induction heat treatment is quite new for us, we need to practice our technique on a couple dozen bars of 4140 before we can apply the correct technique to the bars that will eventually be shipped to the customer sometime next month.
All the bars I am working with have a diameter of 14mm (0.55") and length 400mm (14 3/4"). Most of them arrive in poor condition with lots of rust and some machining grooves on one end, which always cause excessive distortion on the grooved ends after heat treatment, but fortunately not elsewhere on the bar. Although this might seem like an obvious question, but should I consider removing any rust first prior to heat treatment?
Our induction heating machine uses a spray quench system from a coil to cool the heated parts after heating; the heated sections are generally only heated for a few seconds prior to being quenched with water from the orifices of the spray coil.
We are trying to achieve a hardness in the range of 35-40HRC, but so far I have managed to achieve this only one time, with a rotation speed around the axis of 1200rpm and a vertical movement speed of 10mm/s at 50kHz frequency (this can't be changed manually but the machine can handle frequencies up to 120kHz) and about 13kW of power (this is manually adjustable). The other problem is that the bars arrive with varying hardnesses along their lengths. On the most recent bar I heat treated, I took 2 hardness measurements on one end that came out to be 22 and 29, and on the other end I obtained 31, 32 and 24 on the Rockwell C scale. Is it possible to achieve a uniform hardness after one heat treatment, even if the original hardness values are so different?
Does anyone have any recommendations for the best method to achieve a hardness of 35-40HRC for 4140 steel by selecting the most appropriate combination of parameters and calculating how much distortion that can be expected as a result of heat treatment? None of the induction heat treating literature I have contain any equations for calculating the amount of distortion that can be expected; they only offer qualitative solutions for handling this issue. BTW the required case depth we need is around 1.5-2.5mm.
Also, since martensite is quite a brittle phase, should I consider tempering after heat treating? I know that if my hardness is too high, then I can temper to reduce the hardness as well as achieve the required combination of toughness and strength, whilst reducing stresses due to quenching - but even if I am able to achieve the required hardness after the first heat treatment, tempering at a lower temperature should be considered to reduce residual stresses and create tempered martensite. However, we only have the one induction heating machine for heat treating as well as tempering, so this machine would also need to be used for tempering. Any ideas on what power setting would allow me to achieve the tempering temperatures required to achieve my target hardness? I am assuming a low power setting, for example 2.5-5kW, but let me know if there is an equation that I can use to work this out.
Thanks in advance for all your help.
