Every few years I get the urge to build an inertia dyno for testing engines. So it’s cold out and my brain is wandering. The flywheel for this dyno needs to have an adjustable mass to simulate different vehicles. This will work from the polar moment of inertia. Depending on the diameter, the flywheel could weigh over 1000#. The larger the diameter the less weight it will be but safety is a concern. This could be spun 10000 RPMs.
My theory is to mount a shaft on bearings for the axle. The mass would be something like 1” steel plates 16” in diameter. These would be added like dumbbells to set the mass for a given test.
Some of my questions are:
How large of a diameter could I spin 10000 RPMs without fear of explosions if the mass is steel? 7500 RPM would be common. Over that would not so much but possible.
What type of bearing would be best for support?
This is something that I may actually build in house. I want to keep it simple enough to build with a lathe, a vertical mill and a welder. I have ideas on the mass and a way to mount it and drive it. Basically I’m looking to find out what the limitations are to spinning a steel disc and bearings meant to hold up to this job.
All the data acquisition can be bought. I’m not concerned about that.
Thanks…
Thanks…
