Let me start by stating that I'm not a machinist, but a woodworker.
I'm working on a kit for a woodworking power feeder that I'd like to market in some quantity. The power feeder is not meant for a shaper, but rather for router table and lighter table saw use, and for resawing on the band saw. This video shows the feeder resawing 5" thick cherry:
YouTube
It consists of a gear reduction box with 12 mm thick baltic birch plywood laser cut gears driving 3" polyurethane rollers at about 5-40 rpm. I want the kit to be buildable by your average woodworker with a drill press and ordinary drill bits, and it needs to be cheap.
I'm having trouble deciding between threaded and unthreaded shafts for the shafts that drive the rollers. I've built one prototype that uses shafts from fully threaded studs (.5") that measure about .492. I JB Welded a loop of .002 brass shim stock to create a bearing surface. The resulting surface is a slightly irregular .498 or so, and seems like an adequate fit for the inexpensive R8ZZ .5"ID bearings. The threaded shafts make it easy to secure the rollers with nuts and jam nuts. For the gear with this set up I use a thick Nylock nut with blue loctite, and press the plywood gear onto the nut. This set up would require no machine work for the kit builder.
The alternative is using 1045 ground and polished steel shaft which fits the bearings , but lacking threads, creates a problem for retaining the wheels and gears. I can within my budget have the shafts end drilled and tapped by a machine shop for a 5/16-24 bolt that will retain the wheel against a pinned nut on the other side. But the user will have to drill out a nut and pin it for that, and then do the same for a nut that will be a hub for the gear. It seems like drilling out 1/2-13 nuts to .5" ID accurately is a little dicey.
Any advice for these issues is most welcome.
Thanks!
YouTube
Thanks!
