Info on Pacemaker lathe
Likes Likes:  0
Results 1 to 12 of 12
    Dec 2016
    Wisconsin
    111
    22
    Default Info on Pacemaker lathe
    Looking at a pacemaker lathe.
    Would anyone have any info on this serial number.
    SN 62242-41
    I believe it's a 20" raised for swing (around 26"), 120" between centers.
    What would be an average going cost for a ugly but mechanically sound pacemaker?
    Someone bust off the clutch handle at the headstock, which screams neglect to me, yet the hand crank for moving the tail stock is there.
    Jul 2007
    Missoula Mt
    435
    15
    167
    Made 1941 soft ways,not very valuable... 1k...Phil
    Jul 2004
    Houston, TX USA
    31,031
    From 1941 - 79 years old
    Oct 2009
    Oregon
    4,978
    5396
    2555
    I agree with Phil, not worth a lot.
    That's a good size though. 20x120 is an all around good size machine.
    Dec 2016
    Wisconsin
    111
    22
    So would that year still have the removable vee ways, such that I could get them ground?
    Jul 2004
    Houston, TX USA
    31,031
    Quote Originally Posted by Machinist_max View Post
    No removable outer hardened and ground vee ways until about 1947. I would suppose that the smaller, shorter machines were the first to get such things.
    Great stuff here on Greg Menke's web page
    http://pounceatron.dreamhosters.com/...in-15-1940.pdf
    http://pounceatron.dreamhosters.com/...in-17-1940.pdf
    Note the 20 will be the "BIG" series of Pacemakers and your long prospect probably is well over 11,000 Lbs
    This great serial shot shows how plainly there is no horizontal split line showing something added to the upper front way as of 1942
    Dec 2016
    Wisconsin
    111
    22
    Scraping the wear out of that machine seems like a horrible idea then.
    Its not fitting on a grinder for sure.
    Sep 2006
    SW Wisconsin
    586
    59
    161
    Quote Originally Posted by johnoder View Post
    have fun
    My 14 by 54 is a 41 with removable hard ways, SN 62574-41. Is there a good way to make sure that a regrinding would still remain true? I talked to one fellow that had a German lathe with removables, he said he was simply going to reverse them.
    Ed.
    Jul 2004
    Houston, TX USA
    31,031
    Quote Originally Posted by atex57 View Post
    Ed.
    That is a new one to me. How are chances of a photo showing that from the tail stock end?
    Dec 2016
    Wisconsin
    111
    22
    I'm thinking its going to come in around 16,000lbs.
    Has the rapid traverse on the carriage.
    From what I can tell it spent its life doing some deep hole drilling, with it mounted on the tool post. Maybe that helped spread the wear out.
    I don't mind doing a rebuild. I just need a good solid base to start with.
  11. #11
    Sep 2006
    SW Wisconsin
    586
    59
    161
  12. #12
    Jul 2004
    Houston, TX USA
    31,031
    Sure could have fooled me. I do imagine the factory had a hand it that - after the big effort called WW2
    Bulletin 16 from 1943 - page 28 - makes no mention
    http://pounceatron.dreamhosters.com/...16-1943-si.pdf
