early 2000's T30 compressor that came with a bunch of stuff I bought is not performing. It takes way too long to get up to it's 170 psi cutoff and can't keep up with even minor demand. This one has a hydraulic or "suction" unloader that seems to be doing what it should. There is a port fitting like for a copper compression fitting on the low pressure head that has nothing connected (and nowhere has a place for a line from there to attach to), maybe that's supposed to be pressurized to seal the unloader? I've never had one of these apart; is there a common issue this might be or is it more likely to just be worn out? I didn't try to remove the oil cap while it was running to check for massive blowby yet, but I'm thinking maybe it might have a bad reed valve or something. Any suggestions would be appreciated
