Hi smp4616:
You really need to know what press the mold is going to be run in, and then you can get the platen drawings from the molding press manufacturer if you really want them.
Having said that, some dimensions are pretty much standard for Imperial machines and some for metric machines.
The distance between the knockouts is typically 3 1/2" and the locating ring is typically 3.995" diameter on a normal inch machine. (although the locating ring dimensions can vary quite a bit from machine to machine).
The knockout holes in the ejector plate are typically threaded 1/2:13 and the knockouts holes in the bottom plate are typically 1 1/2" diameter or thereabouts.
The mounting hole pattern in the platen is completely irrelevant...just about every molder uses adjustable gooseneck or strap clamps to bolt the mold into the press, so they just pick the closest convenient holes
Other things you need to know is the distance between the tiebars and the minimum and maximum daylight between the platens, as well as the maximum ejection stroke.
You need to know whether they like to use 7/8" tall clamps or 1" tall clamps to bolt the mold in.
You need to know whether the sprue bushing needs to be 1/2" radius or 3/4" radius for their convenience (some molders get pissy if they have to change nozzles).
You need to know which surfaces they want eyebolt holes in.
All of this is specific to the molder and you cannot anticipate all of it until you know the size of press you'll need and how well it matches with what they have.
Most molders have several sizes of presses, but some smaller operators have only one or two.
Some molders are super flexible and some have a real big stick up their asses about what they will accept.
So ideally, before you design the mold, you'll have already talked to the molder you intend to use, and they will pick the best fit from their selection.
They then tell you what they will use and what they demand, and you build the mold to suit.
Cheers
Marcus
