Injury in a shop right next to mine.
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Oct 2010
    Maryland- USA
    3,365
    1933
    2137
    Default Injury in a shop right next to mine.
    A general mechanics shop in the marine trades.
    The guy was chopping a bronze thru hull (short piece of pipe) on a band saw with a 4TPI wood blade on it holding by hand.
    The piece grabbed and took his finger into the blade and sawed about half way through the bone.
    No ideal how bad the injury is- tendons etc as he is off at the emergency room.
    Poor work holding, wrong blade.
    Sucks- band saws can rotate rounds in a instant and tube is even worse.
    Jun 2013
    Oregon
    1,532
    537
    926
    About half way, owee. Hope they can save it.
    Jun 2016
    New York
    1,496
    817
    644
    you know, I wasn't going to click on this thinking it was just going to be "rubbernecking" but that is a useful cautionary tale. bronze is grabby to begin with, and a 4TPI is going to be really grabby!
    HOLDING SHORT PIECES OF TUBE OR PIPE BY HAND ON THE BANDSAW IS A BAD IDEA!
    a piece of wood and a couple of Kant-Twist clamps comes to mind, and for smaller diameters, a tapered dowel. (a tapered chair back spindle is a handy mandrel to have around for all kinds of things.)
    Apr 2007
    West Virginia
    1,016
    488
    403
    I've had that exact thing happen to me in a wood cutting bandsaw with about 3" pvc. No injury in my incident but I never forgot it and never did it again.
    Jan 2014
    Utah
    501
    1276
    202
    My niece tried to cut a rope on a table saw. Luckily, the saw stalled before it pulled her in. She hasn't tried it again.
    Oct 2005
    14,854
    alll that bronze dust inside him is not good either....
  7. Likes g-coder05, SAG 180 liked this post
    Feb 2014
    Sunny South West Florida, USA
    2,764
    10454
    3192
    I once caught an engineer trying to use an approximately 8TPI blade on a vertical bandsaw to cut a piece of .100"Øish stock... What's amazing is that after he got it caught in the gullet, bent the stock, and probably ripped a few teeth off the blade... He went to try again, until I took it from him and cut it on the lathe for him. But at least he had his safety glasses on.
  9. #8
    Feb 2001
    Redwood City, CA USA
    4,961
    178
    902
    I almost got bit last weekend cutting the end off a new tube of Castrol stick-wax metalcutting lube. It grabbed and spun surprisingly quick and hard for a glorified toilet paper tube. I know not to cut rounds freehand on a bandsaw, but thought a lousy piece of cardboard would be no problem. Oops.
  10. Likes Bobw, cyanidekid, JohnEvans, Kjelle, Colt45 liked this post
  11. #9
    Mar 2007
    Milford,Ct
    475
    386
    106
    Got bit by this once though not badly just a minor cut .Since then I keep a small palmgren vise for cutting rounds. I just turn it upside down and clamp the part to cut it . Bill
  12. #10
    Mar 2005
    Kansas
    7,428
    426
    3405
    I received this float lock band saw clamp for Christmas after I did the very same thing. My kiss didn't get a Doc.
  13. Likes Alberic, dazz liked this post
  14. #11
    Jul 2007
    UNITED KINGDOM
    4,758
    2512
    2310
    I'm thinking that if you don't have someone to beat it into you, that this is a mistake that a lot of us make. Hopefully it only happens once and it doesn't result in a trip to the ER. Mine was 1 1/4" PVC pipe, just a minor cut from the pipe end, that was enough to make sure that rounds always get held in a vice or clamp when cutting on horizontal or vertical bandsaws...
  15. Likes SAG 180, Trboatworks, TeachMePlease liked this post
  16. #12
    Jul 2008
    Philadelphia
    1,942
    514
    445
    One way to avoid this type injury is to use the correct piece of gear for the job (no the apprentice). If you must cut round stock on a vertical bandsaw use one of those small vices. Place the stock in the vise then invert it, hold the vise in your dominate hand and proceed CAREFULLY. Also is a good idea to tell the clipboard crew that their is a kitten stuck in a tree on fire out in the parking lot as well.
    But in all seriousness I hope he recovers quickly and IMHO just don't cut round stock on a vertical saw, clamp it proper like in a horizontal. But if you must, and lets be honest sometime ya have to try the above and Christ sake use the correct blade.
  17. Likes TeachMePlease liked this post
  18. #13
    Jan 2007
    Florida
    1,110
    133
    404
    my bride's brother quit his job at the university to get into construction work. he is now short three fingers due to free handing cutting something on a table saw (from the back side)
  19. #14
    Oct 2010
    Maryland- USA
    3,365
    1933
    2137
    I have to admit I did this one time- 6” piece of thin wall aluminum tube on a 3tpi carbide blade.
    Wham!
    Stock spun and trashed the $200 blade.
    Lesson learned...
    It’s right up there with helicoptering a bit of stock in the drill press- gets real exciting and will lay you open if you get nicked..
  20. #15
    Langley, B.C.
    1,661
    335
    970
    Quote Originally Posted by doug8cat View Post
    ...If you must cut round stock on a vertical bandsaw use one of those small vices. Place the stock in the vise then invert it, hold the vise in your dominate hand and proceed CAREFULLY...
    I use a machinist's vise all the time to cut stock in a vertical bandsaw. Inverting the vise is the correct way to do
    it but the trick is to place the stock on the table, flip the vise over and then clamp it. That way the stock stays flat
    on the table. if you clamp the stock in the vise first it will be suspended above the table whether you invert the
    vise or not...
  21. Likes TeachMePlease, DouglasJRizzo liked this post
  22. #16
    Feb 2014
    2,764
    10454
    3192
    Quote Originally Posted by cg285 View Post
    I did carpentry before I got into machining. When I was basically an apprentice at that, I had a 24" square piece with very sharp corners kick back on the table saw, and go winging about 15 feet down the driveway right past me... I was a lot more respectful of the table saw after that...
  23. Likes Kjelle liked this post
  24. #17
    Aug 2010
    Connecticut
    1,899
    1467
    2003
    Some lessons in life are well earned.
  25. #18
    Oct 2010
    Maryland- USA
    3,365
    1933
    2137
    So the blow by blow..
    I just talked to the guy- he’s fine with no tendon damage.
    He told me the blade was dull so he was pushing like hell to make the cut.
    It just keeps getting better and better- dull 4TPI wood blade forced through a piece of bronze pipe..
    There is a line somewhere between a guy without the training to know about hazards and one who doesn’t stop when he can tell something is not safe..
    Maybe the most important upside of no employees.. I don’t have to chase safety issues with someone else running equipment.
  26. #19
    Oct 2005
    14,854
    Quote Originally Posted by Trboatworks View Post
    Yup, should have used a sawzall....or a quicke saw....
  27. #20
    Oct 2014
    Massachusetts
    75
    80
    52
    my mother worked as an engineer investigating accidents at a very large factory ...
    When we were required to do special shop class days at teaching factory, instructor spent almost a whole day describing every way tendons getting pulled from arms when hand gets wrapped around a chuck on a machine the size of that classroom.
    People get complacent working with less powerful tools, getting into habit of stopping drill chuck with hands on a tabletop model then trying that crap on a factory machine.
    Big driving factor is rushing, using subpar tools for the job, because you need done something quick.
