After what seems like a million years, I have the 1024 running. I have two tool posts, a multifix A and an Algra Rapidue which is a Dickson clone. There were a bunch of holders for the Algra but most looked dickson as the flange on the adjuster was too thick. I surface ground them and intend to use them first as I need the algra to make a bolt for the Multifix. Tooling that cam e with the lathe are pictured below but no extra inserts. I'm new to most of this so I would like to know which of these is useful and worth buying inserts for. I'm learning about the nomenaclature ( reading threads here )but don't want to buy a bunch of useless stuff. I have rooms of useless stuff all ready. The 3/4" will work on either post.
View attachment 312341View attachment 312342View attachment 312343 Any advice is appreciated. Dave
Ermmm.. Carbides are magically diverse and capable technology, many long years, already. Fast-moving as to upgrades, too.
Those pushing CNC spindles balls to the walls to earn a few cents each PART need to be as up-to-date as possible lest some OTHER guy pushing a CNC spindle beats their price by two cents.
Good on 'em.
A(ny) hobbyist hasn't got the time, the budget, nor the mass of same-same alloy and same-shape parts to match that "optimization", even if he/we had the wish to do. Our "optimal" can vary from ONE job to the next, not even involve TWO of a thing.
Use what is common, cheap, and generally well-spoken of, all-around use. It WILL be obsolete by bleeding-edge metrics. And also JF get the job DONE more often that not.
Lazy, Iyam.
I've got more than a lifetime supply of HSS/Cobalt and Stellites put by, virgin blanks to some earlier Pilgrim's interesting grind, usable, touch-up-able, or reshaped altogether "my way".
That's all I really need. No further out-of-pocket spend required. Ever again.
"YMMV"
It is SUPPOSED to do.
Same as boats and camels.
Only ripe Durian fruit and fresh cat s**t are fungible goods.
Best to avoid BOTH, if you were not already aware!
Clobbered QCTP holders might also stinketh?
None of my concern. 4-Ways didn't cease working cheaply any more than the Bronze age ended for lack of Bronze nor the stone age for lack of stone.
