Inserting a metal sleeve into a bicycle rim profile
Results 1 to 6 of 6
    Aug 2019
    ISRAEL
    15
    Default Inserting a metal sleeve into a bicycle rim profile
    Hi,
    I want to insert few metal sleeves to specific locations inside a profile of alumium rim- photo for demonstration is attached .
    The rim is after rolling and before seam connection.
    If someone has experience with such a process or can direct me to literature / videos it will be awesome.
    Thanks!
    Oct 2012
    313
    123
    143
    How will they be attached to the rim? Can they be added before rolling? Is the aluminum roll-formed into the hollow shape or extruded? How far apart is each one and how many? What are the general dimensions?
    Aug 2019
    ISRAEL
    15
    They will be attached to the rim with a screw from the bottom of the profile (the sleeves will be with threaded holes).
    They should be placed 120 deg from each other (rim diameter is abour 570mm), the quantity is 3 pcs.
    Cant be placed before rolling.
    General dimensions: 19-20mm width, ~10 mm height, ~15 mm length.
    Thought about inserting it before the connection of the seam and locate the sleeves with a magnet. what do you think?
    Oct 2012
    313
    123
    143
    If the rim has the through hole and the sleeve has a threaded hole, it shouldn't be that difficult. Magnets would probably be the best way to do it.
    Make a jig with magnets to hold the sleeve in place and rotate the rim around until the holes line up.
    Oct 2005
    14,834
    Purpose ?
    and what is our "cut" for helping you ?
  6. Likes bloomautomatic liked this post
    Nov 2008
    Madera county california usa
    2,408
    21
    596
    Ferrous metal in aluminum rim to work with magnetic pickup?
    Must be better way
