inside lapping a bearing bronze bushing
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Feb 2010
    ch
    2,409
    211
    312
    Default inside lapping a bearing bronze bushing
    what do you use as a lap? is annealed copper o.k.? and what compound? will diamond imbed?
    edit: a bushing out of bearing-bronze sliding on a shaft, where i want to controll the fit.
    Virginia
    30,274
    7561
    9466
    Quote Originally Posted by dian View Post
    Bronze, I'm actually used to scraping, not lapping. The lube does the rest.
    I'd seen Herr Pelz make a new Bronze bearing for an ancient B&S SG and have his wedge-shape German DI hold under half of its fifty-millionths division. No lapping required.
    Bronze is also ameneble to "working". As-in stretching the bore, or hammering over a mandrel, clean-up pass on the OD.
    But have a read, our own late and lamented "Texas Turnado" and his last-ever project. The rebuild of a Graziano TS, "Right here, on PM", even.
    He teased through a shop-fab lap design and application that ultimately worked a treat:
    Is it possible to hone the bore of a tailstock accurately enough in a home shop?
    As importantly, there was a ton of discussion wrapped into the thread as covers it all really well.
    Do keep in mind that bearing Bronze and CI are not the same goods? As-in mayhap the LAP should be CI?
    Jan 2007
    Norfolk, UK
    19,590
    15036
    15211
    IMO - Not a good idea, can you press a ball bearing or ball swage etc etc through to bring it to size
  4. Likes SAG 180, richard newman, Screwmachine liked this post
    Oct 2013
    netherlands Asten
    1,158
    714
    503
    i didn't know there were 0.1 Mu indicators,they must be very rare.
    Oct 2013
    netherlands Asten
    1,158
    714
    503
    if you want to really control the fit make it a bushing with a conical outside and a slit and a way to adjust fit by pressing it more or less into the housing.
    the way head stock bearings were made.
  7. Likes Hopefuldave liked this post
  8. #6
    Virginia
    30,274
    7561
    9466
    Quote Originally Posted by janvanruth View Post
    Haven't a klew what system yer in over there given y'all are so hard-headed yah don't even accept the conventional definition of above or below sea-level indicating drowning or simply bicycling to work.
    Inches here. Where the money is. Wonder if there is a message in that?
  9. #7
    Sep 2007
    Cairns, Qld, Australia
    2,832
    929
    795
    I ran some experiments with an aluminium lap in a bronze bush, even after thorough cleaning, the abrasive embeds in the bronze and will scratch up some clean, fresh aluminium surface.
  10. Likes Limy Sami, Mcgyver liked this post
  11. #8
    Aug 2004
    Virginia
    2,452
    179
    967
    I would not use anything abrasive in a bronze bushing. It is too easy to leave abrasive material embedded in the bushing. You didn't say, but if this is oilite bronze then you should consider that what you do may "smear" the bronze and affect the porosity of the sintered bronze. I have had the best luck using an adjustable hand reamer to make bearings for things like tool post grinders and things of that nature.
  12. #9
    Feb 2010
    ch
    2,409
    211
    312
    its what we call "rg7" (CuSn7ZnPb) with a hardness around 70 hb. im looking at sizes of 30, 40 and 50 mm, so an adjustable reamer would be nice, but i wouldnt know where to get one that big and im sure i couldnt aford it. splitting it is an option (and adding a housing with a differential screw) but im trying to keep it simple.
  13. #10
    Aug 2004
    Virginia
    2,452
    179
    967
    Well if you want to keep it simple then I would get it as close as possible in your lathe. Then I would get a three stone brake cylinder hone and stone it by hand. The spring loaded stones will give you fairly equal pressure and I think you would have less of a chance of having abrasive slurry embedded in your bronze. You can get replaceable stones in various grades and the whole setup is very cheap (under $10). Use cutting oil and proceed slowly. I have mounted one of these in a tale stock chuck and used it to hone at very low spindle speed, but I think you can get it dead nuts on by just twirling it in your fingers. It will work on a taper as well.
  14. #11
    Jul 2004
    Houston, TX USA
    30,688
    Boston - but then this is the sintered stuff
  15. Likes Screwmachine liked this post
  16. #12
    Mar 2011
    SWITZERLAND
    1,026
    124
    420
    +1 for pushing through a steel ball. Takes a press, a ball, and oil. Quick and exact, no chips
  17. #13
    Feb 2010
    ch
    2,409
    211
    312
    how much is a 50 mm bearing ball (i need a few bushings in several sizes)? and how do i adjust the fit?
  18. #14
    Jul 2006
    rochester, ny
    1,992
    418
    573
    +2 for pressing a steel bearing ball thru. I did this once long ago, heated the ball in oil by 10 degree increments until the shaft just slid in. Very satisfying!
    edit - just saw your post, I think there was some spring back, so an on size ball will burnish undersize.
  19. #15
    Virginia
    30,274
    7561
    9466
    Given that the stuff turns - or bores - about as nicely as any material yah could ask for - I'm having a hard time trying to understand why you think you NEED to lap it.. but could use an adjustable reamer instead?
    What's wrong with turning & boring it to your best efforts, then seeing to a goodly lube flush and "running it in" under power on the polished shaft it is meant to marry?
    Or a substitute shaft. That's a burnishing process more than an abrasive lapping one, but Bronze is comfortable with that.
    We even take advantage of it to make enduring-good bearings... out of Bronze.
    Go figure.
  20. #16
    Feb 2010
    ch
    2,409
    211
    312
    how much do you think can be "burnished" out that way? shafts are hardened and ground to h6. if i can increase the radius by 2 micron that should do it. on second thought, the bushing will warm up, so it wouldnt be so easy after all.
    (in the end the bushing/collar will not have to rotate.)
  21. #17
    Mar 2007
    Ohio
    32
    8
    C.E.Johansson Mikrokators are available in 0.1 micron (and 10 micro-inch if those are your preferred units).
    Not cheap but readily available. Today's ebay listings:
    C.E. Johansson Mikrokator - metric - mdl. 510-8 - .0001mm per division - FT17 | eBay
    C.E.Johansson 510 E-4 Mikrokator .000010" Dial Indicator & Stand Calibrated 2019 | eBay
    There are also soviet era russian clones out there for less money.
    I've got a 1 micron and a 0.1 micron, paid less than $100 each on ebay.
    Best I see right now for 0.1 micron is $150.
    Mikrokator (+-0.004 mm) - metric 0.0001mm per division. USSR NEW! | eBay
    John
  22. #18
    Jan 2007
    Norfolk, UK
    19,590
    15036
    15211
    If you haven't got a ball, turn a shaft with a ''rounded bump'' in it the dia you want,rounding over with a file ………... it doesn't have to be hardened if it's only a few, just make sure said bump is nice and smoothly finished.
    Then as above heat the bar a bit if you need a bit more.
  23. #19
    Feb 2010
    ch
    2,409
    211
    312
    nice to know. i wonder how you adjust the height on this: C.E.Johansson 510 E-4 Mikrokator .000010" Dial Indicator & Stand Calibrated 2019 | eBay
    black thumbscrew? it seems to be pinching a collar.
    (you might be in the wrong thread.)
  24. #20
    Mar 2007
    Ohio
    32
    8
    Rough position indicator, then fine adjust with screw under the stage that holds the part.
    (you're right, this is the wrong thread for discussing mikrokators, this will be my last post on the topic)
