Hey guys
We will be installing some cone point set screws on some bearing collars on conveyor shafts that keep walking. We were going to use a center punch into the set screw holes on the bearings to make a big indent where the set screw would seat. I wonder if this might later cause issue with removing the bearings as they must slide over this spot for removal. Maybe better option is to drill small shallow hole in shaft and install the cone point screws?
Thanks for any ideas. Eric
