installing crushed carbide on tooling - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,107
    927
    725
    "Grit Edge" hole saws and hacksaw blades are the same idea, and maybe a thousand randomly-oriented grits are best for cutting/grinding away brittle materials like glass. But IME if you can braze on sizeable carbide pieces like wornout or broken inserts, and then grind them in place to a properly-oriented cutting edge, they work better. What is the OP actually wanting to do?
  2. #22
    Mar 2005
    Kansas
    7,800
    473
    3695
    These folks should have what you need.
    Rankin Hardfacing - Broco-Rankin
  3. #23
    Jun 2006
    Kansas
    1,455
    271
    533
    These guys have the carbide impregnated sticks you are looking for. I couldn’t find them on there website but I have orderd them in the past. Home - Broco-Rankin
    Here is another source you might try. B&W Metals - Page 2
    In the past I have broken up old carbide inserts and brazed them on tooling with good results. Just make sure the inserts are not coated the bronze will not stick to the coated inserts.
  4. Likes digger doug liked this post
  5. #24
    Apr 2012
    antelope ca
    15
    15
    Home | KENCO
    they use a tig torch with a 1/4 inch tungsten to melt the base metal and lay on the ground up carbide.
  6. Likes digger doug, PlasmaOnTheBrain liked this post
  7. #25
    Jan 2005
    Victoria, Texas, USA
    4,219
    2488
    1091
    Back in my younger years, I built several devices that fed powdered carbide down a conveyor belt and dumped into a pool of melted metal matrix onto the OD drill collars and on the shoulders of drill pipe connections. Was also used on other drilling tools as mentioned in this thread. It was a type of submerged arc weld process using welding equipment putting out something like 1500 amps and higher. Not your small shop welding type of equipment. They did not use oxy-gas for this process, only for stress relieving after welding. Ken S.
  8. Likes digger doug liked this post
  9. #26
    Oct 2005
    17,214
    Quote Originally Posted by Illinoyance View Post
    I guess they didn't have tools in the hole.
    I did want to salvage my tools.
    Yup, it was fracking in the early days around here.
    A few old timers related it to me, and then I read it in the
    reprinted books "echos from the oil country" where they have pix and
    a good description.
    If your tools are in there, catch them on the way back up....before they
    hit the next county....should be all nice and cleaned off too....
  10. #27
    Aug 2006
    Wisconsin
    1,672
    756
    749
    You don't mention what material you are machining. I also get the impression you want to try to accomplish this on your own, which I think will be a failure. Having said that, there are companies that do very good spray coatings, cbn, diamond, carbide, ect. Here is where I would start, after you get your cutting tools.
    TuffTek | NanoMech
  11. #28
    Oct 2005
    17,214
    Quote Originally Posted by idacal View Post
    okay, i now feel dumb, lol, shows how much tv I watch
    You didn't miss much...Nothing more than a 2018 version Of
    "Mr. Herbert R. Tarlec Jr." minus the plaid.
  12. #29
    Nov 2009
    Michigan USA
    1,136
    84
    237
    Not exactly sure what you are trying to achieve. There are many manufactures making diamond plated tools. Carbide is not as common. There are single pass hone tools, plated form tools and plated turning boring inserts.
  13. #30
    Oct 2005
    17,214
    I am trying to cut cast iron or bronze not sure what it is I'm cutting out can't see it or reach it but I want the ,cobs rough shit, I have rented tools with the right stuff on it and it will cut through 1/2" plate in a couple hundred revolutions . Im trying to get past the blockage in a well without replacing the well. illinoyance when you did it did you just pour the carbide chips in as you had a bronze puddle?
    Quote Originally Posted by athack View Post
    It's a downhole tool, he's trying to drill out part of the tool and surrounding
    rock to loosen up a stuck drill tool.
  14. #31
    Aug 2006
    greensboro,northcarolina
    2,461
    162
    615
    We have used this company to put a carbide grit plating on expanding mandrels to increase grip.
    403 Forbidden
    They advertise lots of other applications as well.
    no Idea why 403 error, the link works.
  15. #32
    Aug 2011
    new plymouth id
    417
    27
    98
    thank you guys for all the advice I think I found a place that has what I'm looking for .25x.187 chips
    Tungsten Carbide Brazing Rods in Nickel Silver, Nickel/Chrome/Boron and Silicon Bronze|Dynarod NS – Dynalloy here is a link in case someone else gets stuck looking all the advice helped me get the right terminology and many places to call if they dont come through so thank you
  16. Likes 4GSR liked this post
  17. #33
    Oct 2012
    Albany Ny USA
    433
    1507
    209
    Quote Originally Posted by metalmaster1 View Post
    Home | KENCO
    I REALLY want to play with a Tig torch that needs a 1/4" tungsten...
    Sorry for the non useful content but Damn... That's gotta be one warm process and one big machine.
  18. #34
    Jan 2005
    4,219
    2488
    1091
    I don't recall a TIG torch being used to apply carbide to drilling tools or even mills or cleanup tools used in the oilfield. Mostly oxy-gas and Stoody rod used. Hard banding used carbide-metal matrix applied with arc and shielding gas. Ken
  19. #35
    Apr 2012
    antelope ca
    15
    15
    Kenco does a lot of earth moving equipment, I know they used tig because I used to make the torches for them.
