Interesting finding on Loctite and taper fits
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Aug 2006
    Kitchener, on canada
    885
    15
    195
    Default Interesting finding on Loctite and taper fits
    We did some experiments at work to determine what the torque carrying capability of joints made by interference fits created by tapers (12-16 degrees included angle) on shafts/hubs. These parts were steel and the surface finish was turned not ground. Using green Loctite retaining compound almost doubled the torque carrying capacity. I was surprised that loctite could have such a significant effect, has anyone else noticed anything like this?
    Jan 2005
    Houston
    6,247
    789
    3010
    Well, it is Loctite, after all....
    There's not enough data to tell if you really did a 'scientific' experiment or not.
    Most of all, the amount of power transmitted is very significant. If you are transmitting 2 lb-ft, I can see getting to 4. Especially if your taper diameter starts at 5".
    But getting 20,000HP through a 5.5" taper instead of 10,000HP? That would be another story.
    And...being a turned surface is also pretty questionable...tapers are really a ground finish situation and percentage contact is critical to their effectiveness.
  3. Likes eKretz liked this post
    Virginia
    31,290
    7561
    9818
    Quote Originally Posted by SBAER View Post
    .. has anyone else noticed anything like this?
    Only "sort of". Usta make my screwdriver shafts (drill rod) to near-as-dammit a standard long taper I happened to have reamers for.
    Everything done, handle gripped in a 4-Jaw, put MAPP gas torch to it.
    Screwdriver shaft gripped in a TS drill chuck. I'd down the torch, cut power, hard RAM the shaft into the mating taper, let friction marry them up as the chuck was "braked" to a stop.
    No Fine Way that shaft was coming back out of than long taper. Twist it in half down at the blade-tip area first, and HAVE done.
    Tapers can be handy features. Loctite jest lets yah "get to the end" a tad lazier and faster with sorrier-finish ones.
    Mind "sorry" is down in the NANO surface details, so all of 'em can benefit, no matter how well ground.
    You'd probably have to section, polish, etch the joining, send out for microscopy shots to collect the proofs?
    Jan 2002
    West Coast, USA
    8,442
    570
    5961
    Jul 2007
    Missoula Mt
    345
    9
    130
    If you really want it bite, freeze the shaft to -50 and loctite the taper and press it together ....Phil
    Feb 2010
    ch
    2,494
    215
    329
    noticed? no, but would not have expected otherwise, as they state to use it for press fits in the instructions.
    btw, you can use anaerobics only once without thorough cleaning of the surfaces. the effect of surface prep. on strenght would be a more interesting one to discuss.
    Mar 2012
    Geilenkirchen, Germany
    2,560
    1506
    1293
    Quote Originally Posted by GregSY View Post
    I think for real security of grip all tapers need to be properly lapped, as done with prop shafts regardless of what machine process is used to create the mating tapers. That said, not all tapers are used for the purpose of grip or grip alone. For instance, tapers are very often used for precise repeatable positioning as well.. So, if the purpose of the OP's test is to compare max torque capability with and without Loctite, the joint would have to be a perfectly lapped one to start with. I think the observed increase in torque the OP witnessed could very well be that the Loctite is making up for a less than perfect mate of the tested taper.
  9. Likes eKretz liked this post
  10. #8
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    Yes, think about it.
    Your surface finishes have deviations - peaks and troughs.
    No loctite - the parts contact peak to peak.
    With Loctite - the troughs in the parts have loctite in there so the surface contact is HUGE in comparison.
    BTW - What is "green loctite"?
    You do realise they have different numbers for different applications?
  11. Likes eKretz liked this post
  12. #9
    Feb 2007
    Aberdeen, UK
    3,904
    1384
    1585
    Quote Originally Posted by barbter View Post
    Well, he did say retaining compound...
    638 is retaining compound, green colour.
  13. #10
    May 2017
    FINLAND
    2,156
    585
    999
    Quote Originally Posted by gregormarwick View Post
    Add 603, 6300, 620 and 648 to your list.
  14. Likes gregormarwick, GregSY liked this post
  15. #11
    Feb 2007
    Aberdeen, UK
    3,904
    1384
    1585
    Quote Originally Posted by MattiJ View Post
    Fair enough!
    638 is just what I have in my cupboard - used it for very large, very thin bronze sleeves that needed to be a press fit but were too fragile to actually press in. Worked great.
  16. #12
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    638 is bearing fit
    603 is oil tolerant shafts
    620 is hi temp
  17. #13
    Oct 2014
    Maine
    1,065
    157
    502
    There are way more than just those. The Loctite Adhesive Sourcebook has a handy chart showing which ones to use when.
  18. Likes Mark Rand liked this post
  19. #14
    Dec 2012
    Se Ma USA
    1,741
    138
    950
    OP, for every action there is an equal and opposite criticism.
    But this thread is all good.
  20. #15
    Jul 2007
    UNITED KINGDOM
    5,028
    2854
    2473
    or 2xx is low strength
    5xx is sealing/hydraulic
    6xx is high strength
    and others?
  21. #16
    Aug 2006
    885
    15
    195
    Thanks for the Sciencedirect link I will follow that up. We could have spent lots more money doing the test that's for sure. This joint is drawn together to the point that the hub is almost yielding, I would have guessed that the loctite would be squeezed right out.
    The reason I brought it up was mostly for people like me that mostly do one-off repairs and need all the help they can get to make their less than perfect workmanship hold together.
  22. #17
    Oct 2014
    Maine
    1,065
    157
    502
    Quote Originally Posted by Mark Rand View Post
    and others?
    That's not correct. The 600 series encompasses the retaining compounds, not all of which are high strength, like 641. 200 series include the threadlockers, and cover a range of strengths; 222 (purple) and 263 (red) are very different beasts.
  23. Likes barbter, Mark Rand liked this post
  24. #18
    Feb 2004
    peekskill, NY
    25,320
    5166
    Your surface finishes have deviations - peaks and troughs....
    +1
    The ast-turned parts probably had about five for ten percent surface contact between the two mating surfaces. Locktite
    increased that substantially. If you *really* want them to stay together, flux, heat, and apply ez-flow silver solder....
  25. #19
    Jan 2005
    Houston
    6,247
    789
    3010
    The people in industry who 'really' know their stuff when it comes to tapers specify an 85% or greater contact as determined by bluing/checking.
  26. #20
    Feb 2004
    peekskill, NY
    25,320
    5166
    The people in industry who 'really' know their stuff when it comes to tapers ..
    Typically those folks don't use as-turned parts. If you put enough prussian blue on it, anything looks good.
  27. Likes dian liked this post
