Webley91
Cast Iron
- Feb 13, 2009
- London, England
How much interference fit would be recommended for a 38mm OD bearing bore repair sleeve shown in the attached list? I would be installing it into an aluminium alternator housing (see attached image).
My intention would be to replace the raised bore side wall shown in the image with the sleeve. There appears to be enough material thickness to bore out from the damaged inside diameter of approx 35.5mm to 38mm to fit the sleeve.
The size of sleeve I would be using is 35 x 38 x 15.5mm
Also, what type of retaining compound (if any) would be recommended for this application? Expansion of the parts due to heat during operation could be an issue.
Thanks for any information.
