I am designing a part that requires an internal thread on the ends of a thin-wall 5" OD 60" long welded 304 stainelss steel tube.
The current design has a UN 24 TPI thread in a 0.065" wall thickness tube. The major diameter of the thread penetrates about half way through the tube wall thickness. Tube OD mill tolerance is pretty tight at +/- 0.02.
I imagine tube end roundness (ovality) and deflection will be problematic during single point threading on a lathe with a steady-rest. Is it possible to force the tube ends into round by clamping a collar around the tube OD during machining?
If 0.065" wall thickness is unachievable, what minimum wall thickness & thread pitch would you recommend? Available tube wall thicknesses are 0.065, 0.083, 0.095, .109, .120, and .134”.
Are there any special fixturing tricks or other threading techniques that will make this job easier?
Thank you!
Thank you!
