We have a chronic problem with pressing an axle into a wheel hub.
It goes in with clearance, then gets hydraulically pressed to swell and lock the pin.
But such is the tolerance, that the clearance varies by 5:1. The combination of small pin with large hole doesn't always lock.
And unfortunately the pin must press flush with the surface of the hub, so making the pin longer is not an option. The combination of large pin with small hole would protrude.
So I had the idea of grooving the inside of the hole, but it's only 5/16 in. dia. so boring grooves would be a pain.
But why not thread the hole with a tap? Maintaining the same through bore. It would be relatively cheap and easy, and would provide extra hidden volume inside (not visible to the customer) to "absorb" the extra length of a longer pin.
This is a big customer and I'm putting my neck on the line to suggest it, so I'm asking you experienced folks if it sounds practical.
