Hello!
At work we have been doing some internal threads that keep coming out slightly different per part. One will be very loose, the next will be very tight.
We are using a ½-13 long reach tap cutting into polypropylene, and need the thread to be about 4.5 inches long. It creates a threaded tube that is used in some assembly’s we are doing, but when putting stuff together, some can be hand tightened, some are too loose, and others are hard to turn at all. Everything gets done with the same tool on our turning center and we started to buy undersized rod in order to bore out the center to make sure it was the right size. I am not using coolant as the material should self-lubricate, and the ones we have available may damage it.
Any idea what might be happening there? We are hoping to iron it out so we can automate the processes a bit more.
Thanks in advance!
(Also, first post. Sorry if it’s in the wrong place.)
Thanks in advance!
