Hopefuldave
Cast Iron
- Apr 1, 2010
- Surrey, England
ok, it seems pretty simple to invert a regular hydraulic jack (rearrange the fluid pickup, external reservoir etc.).
BUT with an air-over is it just an additional step of inverting the air cylinder using a few 90-degree hydraulic elbows, or will I run into problems? Looking at pics remotely (don't have one here yet...) it looks like there's only a hydraulic union between the cylinder and the base of the jack. e.g. 06184 Heavy Duty Air Hydraulic Jack 20 Ton Bottle Jack Pneumatic Lift Ram Car Va | eBay
End use will be mounting it on a trolley between the top cross-members of an H-frame press I'm planning to build for the Shed of Danger as I want to avoid the HF-style wobbly intermediate platform with the jack base sat on it and tooling mount welded out of square underneath, tooling can screw into the end of the jack's ram.
Dave H. (the other one)
