We need to machine several large rollers. These vary around 12-16 inches in diameter, 12 to 24 inches long and look something like the attached. They only need like a 1 inch side wall thickness. Buying solid material ends up being very expensive and also very very heavy to work with. Would it be possible to take flame cut or laser cut rings that are bigger on the OD and smaller on the ID and have them cut to match the radii of the complete part? They would would get welded together from inside and then you would end up with a part basically big on the OD and small on the ID that you could machine to the right size. It would be a lot of roughing over corners. Does this make sense and has anyone heard of it?
