Jacobs #1 taper adapter
reodds
Sep 18, 2019
Hi Everyone, I am a new forum member, and just purchased an antique drill press and need some help. the spindle is a single piece ending in a Jacobs #1 taper and came with a 0-1/4" Jacobs 1A chuck. I have done a bit of research online as well as this forum and cannot find if there is any simple way to adapt the spindle taper to a #33 Jacobs that will allow me to use 1/2" capacity chucks.
I am NOT going to use this with any lateral loads, just simple straight drilling. Does anyone have any suggestions?
Thanks for your help!
Roger
I've never seen anything with that taper that went larger than 1/4" and I suspect the reason there's no adapters is because those were light duty drill presses and JT33 is normally associated with 1/2" chucks.
Read some of the warnings in this thread about what can happen when you mount an oversize chuck.
Jacobs taper adapter
Putting a 1/2" chuck on a machine probably designed for a 1/4" chuck does not sound like a great idea.
Thanks everyone for the info. As I said, I am just drilling with the press, no side loads at all, at low speed. The drill press itself is an antique Hamilton Sensitive drill press, and is far from light duty. It was probably setup for production drilling in small stock which explains the 1JT and 1/4" chuck.
I ordered a Jacobs 31-01, which will at least allow larger than 1/4" drill sizes. I will not be using the press for heavy duty drilling, mostly light aluminum and perhaps occasionally wood.
Thanks again!
Roger
Thanks again!
Roger
Kinda flip flopping eh ?
Need Help Identifying Drill Press
As you were told in the "I.D. thread", that machine is fine as it is, get another DP for your 1/2" capacity chuck.
Your plan for light-duty work is fine, but in reality it won't work. You will drill a hole on the edge of a small part and the bit will catch and the part will be spinning on the bit. That will side load the chuck and may bend the spindle.
