roadcracks
- Jun 7, 2015
I'm looking for a #18 Jarno taper dead center.
Does anyone have one to sell?
Thanks.
Thanks.
I agree the adapter route is one way to go.
Found this on eBay, it could be machined to fit. http://www.ebay.com/itm/USED-GORHAM-20-JARNO-LATHE-DEAD-CENTER-
It's 0.25 large on the big end and 0.125 on the small end. Probably could turn it in my lathe but I would still like to grind it after to assure a proper fit. All that would cost me a lot more than buying a new one from Stark Industrial for about $230. Maybe I'll have to bite the bullet and come up with the $230.
Hello Wille06709
I found one at Stark Industries about $230.
Thanks for your comment.
I like the Jarno also it makes sense compared to all of the other systems.
Am I wrong in thinking that with the Jarno system of tapers where all the taper per inch and angle from center are the same regardless of size, a lager size will fit in a smaller female taper but just wont go in as far?
By definition, Jarno is .600" taper per foot on diameter, regardless of size
The 1/8" difference between an 18 and a 17 (if there was such a thing) would mean an axial mismatch of 2.500" - because .600" taper per foot on diameter is also .050" taper per inch on diameter - and .125 divided by .050 = 2.500
Confirming that the lazy man's way... the 10EE spindle didn't actually expect to use a full #12 Jarno, but rather a slug with integral, smaller DC ELSE one that adapted to smaller MT.
The #12 hangs out far enough to grab scarce daylight on a mere 20" c-to-c lathe, so I picked up a #11 Jarno DC expecting merely less-intrusive hang-out.
"Curses, foiled again!
Hadn't given a thought to Monarch only having used the 'middle' of the #12 jarno.
It slid clear down the bore!
So if i'm understanding this correct, you can put an oversize Jarno taper in a smaller female Jarno so long as the small end of the male taper will fit into the large end of the female taper. I have a 15X48 Clausing with a L1 spindle nose, It appears to have a #18 Jarno taper on the inside that is about 2 1/2 long. Originally the lathe had a spindle nose bushing that reduced to a #3 morse taper but is missing and doesn't seem to be readily available anywhere. There doesn't seem to be a lot of Jarno taper tooling available anywhere. I can find some larger Jarno taper centers that's why i'm asking before buying something that won't fit. The #18 Jarno taper has a large end of 2.25, The #20 Jarno has a large end of 2.50 and a small end of 2.00. Shouldn't it slide in with 5 inches hanging out the front?
If one takes a look in B5.9 Spindle Noses they will see L1 had either MT5 or American Standard 200. L2 has Am Std 250 - both are .750 taper per foot on dia.
Fair chance Clausing - wanting bigger - cobbled up their version of the non existent Am Std 225
Fairly easy to confirm by measuring. If taper is nearer .750 per foot on dia. than it is .600 taper per foot on dia., it IS NOT Jarno
Notice
