Jet Lathe head stock oil fill hole location?
Results 1 to 6 of 6
    Jul 2003
    39
    Default Jet Lathe head stock oil fill hole location?
    I'm working on a Jet GHB-1340 and cant find a fill plug for the head stock. Dues this model have one or must I remove the cover plate.
    Thanks!
    Feb 2014
    FL
    3,812
    12552
    4487
    Quote Originally Posted by Rod MI View Post
    Thanks!
    They figure the motor will die before it ever needs lubrication...
  3. Likes BillE liked this post
    Oct 2005
    19,550
    Quote Originally Posted by TeachMePlease View Post
    Naw….they come as a kit...your supposed to finish the machining by drilling and tapping one on top.
  5. Likes BillE liked this post
  6. #4
    Dec 2010
    Sydney Au
    540
    90
    86
    Before the subject gets locked, after working on something similar a couple years back, oil fill....or maybe it was the drain(?) was aft of the chuck, under the sheet metal paneling - for some reason best known to the Chinese - you might look there!
  7. #5
    Jul 2013
    atlanta, ga
    158
    12
    90
    Iím not familiar with that exact model, but against my advice, a guy I know bought a Jet 1340 recently. His came with the DRO mounted and a rubber headstock cover. The oil fill is under the cover. On his machine removing the molded rubber cover required also removing the factory-mounted DRO. Once all that is done youíll find a plug that blocks a hole thatís just too small for your smallest funnel. I believe he wound up trimming the piece of rubber to clear the mount for the DRO.
    If your machine is anything like the one my acquaintance has, go ahead and get very comfortable with the whole process as youíll be doing it regularly. His machine leaks oil like a sieve... itís entirely possible they didnít even install oil seals. If there are seals installed they... donít do very much at all. Thankfully the QCGB seems to hold oil better than the headstock.
    Additionally, if you plan on using the machine for any sort of real tapping operations, prepare to be unimpressed there as well. The tail stock turret lacks any provision to actually hold the drive-tang on an MT3 shank. Probably best to go ahead and get yourself an MT3 reamer to touch up the ram and stay away from reputable, American-made MT3 shanks as theyíll surely be harder than the Chinesium tail stock turret and youíll run out of material to ream quickly. Whatever chuck Jet put in the box with the machine likely will barely hold a drill, may bend or break if you drop it, but probably isnít so hard to wear out the quill.
    Donít expect the three-jaw chuck Jet provides to grab anything in its range concentrically and expect have to indicate every part, every time if you use their four-jaw as it will not ever repeat. Donít expect to ever get the removable gap back in either.
    Despite all this, my acquaintance is reasonably happy with the purchase, despite its many limitations. He wanted something new... and he got it. He doesnít mind that it only looks like a big-boy machine. I donít think he even owns a precision level, so he doesnít even know if the bed is twisted. It doesnít bother him that it uses oil like a worn out BSA 650, or that any part of the machine youíre likely to touch regularly is knife-sharp and just waiting to cut you. It was shiny and brand new when he got it and will likely make three or four more new Jet lathes before any decent American post-war machine even needs re-scraping.
    Iím fully aware that my ďlittleĒ Clausing 1300 isnít held in high esteem by many members of this community. All the same itís more than accurate enough for me and weighs easily double what the Jet does. The bed casting is wider and thicker and the $6500 less I spent on it left a lot of budget for tooling.
    Chances are this post will be locked. Best of luck with your lathe all the same. Use it, enjoy it as best you can and hopefully the experience is good enough to convince you to keep at it with a better machine whenever you wear the Jet out.
    Be safe and stay healthy
    Jeremy
  8. #6
    Mar 2004
    Edison Washington USA
    10,646
    1064
    5735
    Jet sourced from different factories over the years- but here is the current manual.
    https://content.jettools.com/assets/...57A_man_EN.pdf
    "Fill by pulling pluglocated on top of the headstock cover,underneath the rubber mat."
