metalmagpie
Titanium
- May 22, 2006
- Seattle
I am about to replace the 207 bearings in my stephead's spindle pulley assembly. When it was taken apart, an inner and an outer spacer were found. My outer spacer is 0.1mm taller than the inner (about .004"). When I hold the bearing stack with spacers and compress the inner races together, the inner spacer fits solidly with no play.
I want to reproduce this with new bearings. The new ones won't be identical to the old ones. I can grind the spacers to suit, but I don't understand how to determine what the spacer lengths should be. Looking for some wisdom here.
metalmagpie
metalmagpie
