JT2 1/2 SPINDLE Need a chuck
Results 1 to 10 of 10
    Aug 2017
    Rhode Island
    5
    Default JT2 1/2 SPINDLE Need a chuck
    Good Evening,
    ****Disclaimer*****
    I know nothing about drill presses or machining.
    ok so I have an old AMT Drill Press model 4030. It needs a chuck. In my research I haven't been able to find one, it seems to be an odd ball size used many eons ago in a land far far away. That being said could someone help me come up with a solution to this dilemma? Throwing the press away is not an option, I am sure there is a way to either fit a chuck on or find one that is close enough to use.
    Any help is appreciated.
    Chris
    Feb 2006
    Indiana
    12,733
    638
    3710
    Do you mean you want a 1/2" drill chuck with a Jacobs no. 2 taper? If so, they are easy to find, like on Amazon or eBay, in various makes and quality/price.
    There is a Jacobs no. 2 short taper, but I am not aware of a 2 1/2 taper.
    Taper dimensions: Victor Machinery - Metalworking tools and supplies
    Pick a chuck and use your Prime membership to buy it from Amazon Prime. If you get one that does not fit, you can return it free and it will not cost you anything.
    Larry
  3. Likes Solomon liked this post
    Aug 2017
    Rhode Island
    5
    Thank You Larry,
    I appreciate your time.
    I took this picture of the spindle in the press. My question is do I have to remove the spindle or can I measure the very bottom of the taper then measure the top just below the nut and match the measurements to the chart you provided?
    chris
    ****Update****
    I used the chart provided and I did some measurements.
    listed here I used the Jacobs Taper dimensions Victor Machinery - Metalworking tools and supplies
    What I came up with is as follows:
    A .385
    B .329
    C .881
    The closest one I fall on is a JT#1 but the C dimension is way off. ( The C dimension was measured from the bottom of the nut to the bottom of the arbor.)
    Feb 2006
    Indiana
    12,733
    638
    3710
    Please note that photobucket is going out of business and has become unnecessary. You can post a picture directly from your hard drive to the Practical Machinist site to embed it in your message. Hover your cursor over the icons above the "quick reply" window and click on the one labeled "insert image" and follow the logical path of "from computer" and "select files."
    Larry
    Aug 2017
    Rhode Island
    5
    Thank you for your response,
    Maybe I can clarify some things with pictures and measurements. The first picture is self explanatory. With the link you provided me with I took some measurements. I also used this link--------->Victor Machinery - Metalworking tools and supplies to guide on where to measure.
    According to the above link that shows the Jacobs Taper dimensions, I measured from the bottom of the nut to the bottom of the arbor. This is the C dimension.
    My following dimensions are:
    A .385
    B .329
    C .881
    According to the table that you linked me to the only Jacobs Taper that is close is the JT#1. The length is not even close.
    The second picture is the plate on the front of the press which shows the size of the chuck... and the size of the taper.
    Thanks for your time I appreciate it.
    Chris
    Mar 2019
    What did you buy and where did you get it. my old chigago model DP-515 has the same capacity chuck 1/2" and spindle JT# 2 1/2 . Im trying to find a keyless replacement and having a hard time
    Jul 2001
    North Carolina
    1,910
    151
    372
    I remember reading somewhere that the 2-1/2 Jacobs taper
    was something developed for Import drill presses.
    I don't remember the reason, something like a patent issue.
    I don't think anything of American origin bears that taper.
    -Doozer
  9. #8
    Jul 2003
    savannah, jaw-ja
    1,715
    1143
    403
    Doozer got me to thinking...
    I found an arbor, but no chuck on this site, if it is there, I didn't find it. There are listings for chucks with a JT "2S" - but who knows what that means.
    JT2-1/2-25.4 | S Shaft Chuck Arbor | TAKURAKOGU | MISUMI USA
    Edit - found this old thread on another board, complete with a guest appearance from our own Jim Rozen!
    JT #2-1/2 means exactly that!
  10. #9
    Dec 2010
    Mifflintown, PA 17059
    1,722
    20
    183
    I don't know where a JT2.5 can be found. I'm stuck with JT6 but now see Jacobs has one in 1/2" I did buy it and so far it's much better that the Chinese brands but it too is made in China! I have an Accupro and one that came with SPI quick change, I hated both of them!!!! Problem I see is the pilot on the wrench is too small. If possible get the Jacobs brand but I'm told they all are made in China.
  11. #10
    Nov 2006
    Southern California
    974
    5
    105
    Quote Originally Posted by Froneck View Post
    Get US Made new old stock Jacobs chucks on Ebay.
    Jacobs # 34 Drill Chuck/Key, JT6 Mount, 0-1/2" Capacity, NOS, rac3 | eBay
    848 Jacobs # 34 Drill Chuck, JT6 Mount, 0-1/2" Capacity, NOS | eBay
    Or if LFA (made in France) is good for you:
    LFA 0-1/2 Heavy Duty JT#6 Jacobs Key Type Drill Chuck MADE IN FRANCE UPC 43601 | eBay
