Is it just me, or does Boeshield have the worst spray head of any anti rust spray ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,292
    2787
    5609
    Default Is it just me, or does Boeshield have the worst spray head of any anti rust spray ?
    Seems like every can of Boeshield I get, it sprays ok at first..but even in the beginning it sprays a fairly narrow pure liquid shot, when one would think it would spray a more diverse mist like pattern of spray. But then about mid can, it gets sloppy as hell and is dripping from the spray head with each shot. Others have the same problem ?
    Of course there are alternatives such as CRC....but for certain applications Boeshield seems to prevent rust a little better except for it's ridiculous spray pattern and leakage. Just hard to believe in 2015 they haven't figured out how to make an aerosol can spray head and wondering if only I get defective ones ??
    Sep 2004
    FL
    192
    33
    LPS3 is worse. Never got to use a full can unless I sprayed it all at once.I think it's the wax that plugs them.I relieved the pressure and poured the contents of many partial cans into a container for paint brush use.Alternatives waxoyl homebrew or rigging slush homebrew.
    Dec 2000
    51,292
    2787
    5609
    Quote Originally Posted by deltap View Post
    In a way LPS3 is worse but at least it makes sense that it would be since it is much thicker and stickier than Boeshield. I would think Boeshield would spray more like aerosol paint...but it doesn't for some reason.
    Mar 2009
    Brunswick Oh USA
    4,514
    5011
    2687
    I've never used Boeshield, but LPS3 does a lousy job of spraying. If Starrett could have a better rust preventative, they sure do have the best mist spray of any rattle can. It does prevent rust, but short term.
    Dec 2007
    North Carolina
    836
    256
    110
    Use Boeshield by the gallon. Decant it into plastic bottles with adjustable spray head. Works fine with no leaks and controllable spray. LPS Rust Preventive - use it by the gallon and decant into same spray bottles; just keep the bottle full to avoid clogging of spray nozzle; works.
  6. Likes Winterfalke liked this post
    Jan 2002
    West Coast, USA
    7,684
    474
    5107
    The Boeshield spray head is designed to be used with a tiny (and supplied) plastic "straw" about 4" long. Trying to use it without the "straw" in place is usually an exercise in frustration.
    The wax in the stuff does tend to gum up over time.
    Princeton, NJ
    375
    14
    329
    Never used boeshield, but I do like LPS3 a lot. My method has always been to spray overly heavy, and then spread it around with a soaked cloth. Works for me.
  9. #8
    Dec 2000
    51,292
    2787
    5609
    Quote Originally Posted by E.F. Thumann View Post
    The charms and techniques of LPS3 are irrelevant to my point. LPS3 is a more heavy cosmoline like chemical which does prevent rust better than Boeshield but smells awful and is way more difficult to remove. Boeshield is more desirable for spray on items that might rust from light dew point situations as it smells ok and is easy to remove. LPS3 is for more long term anti rust or outside use where something could get rained on.
  10. #9
    Dec 2004
    uk
    14,057
    4552
    6700
    If its a std areosol can, have a look at ebay or some of the graffiti spray shops, there’s a wide range of aerosol nozzles available and there pretty darn cheap too. For some reason few people seam to consider or realise this is easily done, they just pull off and simply push back on.
    I often end up swapping nozzles from one can to another to get the spray pattern i desire. Weather thats for a oil, paint or cleaning solvent, can make a job go a lot faster and easier too!
  11. Likes dgfoster, Winterfalke liked this post
  12. #10
    Jul 2006
    rochester, ny
    1,888
    378
    520
    +1 for adama!
    I got fed up with nozzles on my Rustoleum rattle cans clogging, they can't be turned upside down to clear them. I called the company to complain and they sent me a whole bunch of spare nozzles. You can also soak them in solvent to clear, but what a PIA for a cheap little piece of plastic.
  13. #11
    Jun 2012
    Michigan
    4,628
    4240
    2796
    Quote Originally Posted by Milacron View Post
    Have you looked into LPS 2? Or even LPS 1?
    We use 2, and haven't really noticed any problems with the sprayer in over a year.
  14. #12
    Guncraft Guest
    I thought maybe I got a couple junk cans. I have been using Boeshield off and on for a couple years on hand tools and cast iron woodworking. I hardly reach for it now ever since the second can started to clog...
    Andy
  15. #13
    Nov 2009
    Massachusetts
    306
    91
    I'd be tempted to heat the nozzle assembly up to the melting point of the wax, and try to spray something.
  16. Likes SteveBausch liked this post
  17. #14
    Jan 2006
    Brookfield, Wisconsin
    3,935
    216
    349
    Have gone through over a dozen of Boeshield's Rust remover/inhibitor product. The Rust remover does drip after awhile.
    For the Rust inhibitor I use with or without the red straw . Without the straw it sprays a semi-mist form , right until the end. Dripping must have been minor or else I would remember it.
    I get my Boeshield from Sears or Rockler.
  18. #15
    Sep 2005
    South Carolina USA
    4,478
    2154
    1307
    Chances are, all of the nozzles are probably made by the same company. There are numerous options as to pattern, orfice size, etc. Might just be a poor choice of nozzle type.
  19. #16
    Mar 2009
    VA USA
    504
    24
    165
    Just because it's New Year's Eve, and nobody else has taken the opportunity...
    It's just you!
    Happy New Year PM!
  20. #17
    Mar 2011
    Huron
    1,352
    1895
    845
    I never buy aerosol cans if I can help it, it's like paying extra for and inconvenience. I agree, buy it by the gallon and use a spray bottle; WD-40 makes a nice one. Also, +1 to replacing the spray nozzle with one from other cans, been doing that for years.
  21. #18
    Jan 2012
    Michigan
    100
    520
    52
    Yes. Exact same problem here. It sprays good for a while, then the terrible sputtering mess you describe, then nothing at all.
    So what to do? The dude in this video sprayed compressed air into a "dead" can of wd-40. https://www.youtube.com/watch?v=y0asTeFlTck
    I figured the video was BS, but tried it anyway. I could hardly believe it but my previously dripping and then "dead" can of Boeshield sprayed like a new can. I sh1t you not. Like new. I sprayed maybe 5 seconds into the can.
    Does it just clear out the tube into the can or actually pressurize it? I don't know, but I didn't have to throw away a 3/4 full can this time!
  22. Likes neilho liked this post
  23. #19
    Mar 2006
    Vershire, Vermont
    1,974
    1260
    608
    And here I've been throwing away partially full aerosol cans for years.
    Jesus, that's brilliant. Duh! Why didn't I think of that?
    Neil
  24. #20
    Jul 2011
    Navasota / Whitehall Texas
    3,578
    2627
    1982
